DIY Headlight Restore
Old Dec 24, 2009 | 11:45 PM
SorakS2K's Avatar
Default DIY Headlight Restore
Easy to Use... All you need are these. "BUT YOU HAVE TO FOLLOW THE INSTRUCTIONS THAT CAME WITH THE KIT."
1. 3M Renewal Headlight KIT $25.00 - AutoZone/Petboys/Kragen
2. 1600 RPM Electric Drill
3. Water Bottle Spray
http://img34.imageshack.us/img34/2033/12242009598.jpg
Before PICS
http://img706.imageshack.us/img706/8596/12232009591.jpg
Before PICS
http://img46.imageshack.us/img46/6357/12232009589.jpg
Before PICS
http://img188.imageshack.us/img188/5906/12232009592.jpg
Before PICS
After Pics
Like Brand New!!!! Hope you guys like my post.
Old Dec 24, 2009 | 11:54 PM
MasterForce's Avatar
nice...
Old Dec 25, 2009 | 09:18 AM
cuonice's Avatar
Very nice, thanks for sharing!
Old Dec 25, 2009 | 09:43 AM
04S2kSS's Avatar
im gonna have to give this a shot... my headlights arent that bad...
dre
Old Dec 25, 2009 | 06:32 PM
SorakS2K's Avatar
dre
Try skipping the Sanding part if your headlights are not that bad.
What i would like to recommend is try using the gray rubber thingy and water spray bottle. then use the polish foam and solution, see if it works, if not then follow the instructions from the KIT.
--danny
Old Dec 25, 2009 | 09:33 PM
Boosted_Talon's Avatar
The "gray rubber thingy" is a trizact 3000 grit pad. It's pretty much like a sponge in terms of softness. Make sure to get a lot of water on the light when using it. Dry it, then hit it with the Orange buffing pad and the 3M rubbing compound they give you.
If that doesn't work, the order goes: 500 grit (the orangish brown looking sand paper), 800 grit (the white and purple sand paper), trizact 3000 grit (gray pad) with water, and then the orange buffing pad with rubbing compound. That's what the kit tells you. Make sure you spend a lot of time on the first two steps. If not, it won't turn out too well. Good luck! I did a write up on this somewhere with pics as well. Someone else did too. This is a great kit!
Old Dec 28, 2009 | 12:18 PM
MurderS2K's Avatar
how many times are we going to get this post????
Old Dec 28, 2009 | 12:21 PM
04S2kSS's Avatar
One more time when i do mine....
Jk....
Thanks for the suggestions guys...
Dre
Old Dec 31, 2009 | 07:29 PM
madcowdk's Avatar
great write up! Thanks.
Old Jan 1, 2010 | 02:26 AM
BlackBearTX's Avatar
You have swirls in your headlight it looks like :<
