Dp Wheel Glaze
Old May 16, 2007 | 04:46 AM
MikeyC's Avatar
Originally Posted by globallyoff,May 15 2007, 09:48 PM
When I was changing out my track pads recently back to stock, I cleaned up my wheels while they were off the car and polished them with Klasse SG. It def made a difference.
Sealing/waxing your wheels makes a big difference not only in how easy they are to clean up but also in looks. I put some DP Wheel Glaze on my wheels every couple of months and also after every wash I apply a spray sealant or spray wax.
Old May 16, 2007 | 09:13 AM
GTScott's Avatar
I agree with the comments about the wheel wax. I had the same issues when I was using the PB's stuff - going on WAAAAY too thick. Once I backed off, it worked much better.
The ZAIO went on incredibly easy. I basically applied it like I would a sealant but with a MF cloth. I let it sit a minute and then wiped it off. I was pretty skeptical when I was told to try this as I didn't think it would hold up to the heat. However, I was wrong as it has lasted better than anything I have put on the wheels. In addition, it also looks incredible.
-GT
Old May 16, 2007 | 10:51 AM
Ubetit's Avatar
Originally Posted by NFRs2000NYC,May 12 2007, 07:26 PM
I have the best anti brake dust tip for you guys.....
SWITCH TO AP1 BRAKE PADS!!!!
I have a few set stockpiled at home. Right now i'm running Axxis ultimate street pads and they dust like crazy.
Old May 16, 2007 | 03:05 PM
APEXSEAL's Avatar
Will this discolor aftermarket wheels such as Bronze CE28n ?
Old May 16, 2007 | 06:53 PM
Ch0pper's Avatar
I've always polished my wheels. It really makes a huge difference in cleaning and the look.
Old May 17, 2007 | 04:14 AM
GTScott's Avatar
APEX...I would not think that this would cause a problem with your bronze wheels. I used Klasse AIO on powder coated wheels on my other car and have never seen any problems. If you have to be 100% sure, try it on a small area first like anything else.
Old May 18, 2007 | 08:42 AM
Gatsbee13
Guest
Posts: n/a
Considering between getting Wheel Wax or DP Glaze from autogeek. Both are highly recommended. Has anyone used Wheel Wax? its a buck more expensive..
whatever is better.
Old May 18, 2007 | 08:45 PM
philbert's Avatar
So should I apply a coat of Acrylic Jett Trigger to the wheels? Or would I want to use Prime? Or even both? (though I'm not sure about using the Carnauba Prime...??)
Old May 19, 2007 | 05:52 AM
MikeyC's Avatar
whatever is better.
I've used both and personally I prefer the DP Wheel Glaze. It seemed to last longer and left a slicker surface.
You would want to start with Prime. The polishing power of Prime will help to remove any residual brake dust and road grime. You can then follow up with Trigger for longer lasting protection.
You can use the carnauba version if that's all you have, but the acrylic version will likely last much longer.
Old May 19, 2007 | 06:58 AM
philbert's Avatar
That was my initial thought. One of these days I'll place another order and end up with pretty much the whole Werkstatt line.
simonprelude
Jun 1, 2005 01:13 PM
speeeding
May 18, 2003 10:48 PM
