A Few Questions
Old Mar 7, 2006 | 12:13 PM
jmargelo's Avatar
Default A Few Questions
Sonus Detailing Spritz vs Carnuba Spritz
What is the difference between these products? I'm not sure which of these I need. I will have a few layers of P21S/S100 on my car. I would've assumed from the name that the Carnuba Spritz would be ideal to use as a detailer, but Autopia's Perfect Shine kit includes the Detailing Spritz instead so i'm a little confused.
Also, I currently own NTX and Mother's Detailing Spray. Will either of these be compatible/as good on top of P21S?
Klasse Sealant Glaze: To use or not to use?
Basically I want to know what the difference will be between the following scenarios:
Klasse AIO + X Layers SG + Y Layers P21S
Klasse AIO + Z Layers P21S
X+Y = Z
The sealant glaze is apparently more difficult to use, requires more time between layers, and adds $20 to the bill. Is it worth it? ....on Silverstone?
Can't finish in one day, no garage
If I don't finish applying all layers of whatever in one day, do I need to wash/dry the car again before continuing to add more layers, or is dusting sufficient?
Polishes: Menzerna vs. Sonus
Is one considered better than the other or should I just pick one?
PC Pads: Sonus SFX, DAS & CMA
Again, Is one better than the other? I'm having a hard time deciding who to buy pads from.
Thanks is advance guys/gals.
Moderator: If you would like to integrate my P21S vs S100 thread with this one, then feel free.
Old Mar 7, 2006 | 01:08 PM
speed_bump's Avatar
Some people have a problem with SG but I have never had a problem with it in the many years I have used it.
Carnauba Spritz for people with Carnauba wax
Detailing Spritz for people who stop after putting on the Klasse
do I need to wash/dry the car again before continuing depends on how dirty it is and what stage you are on. If it's not bad and you use a california duster and do a quick detail with compatible product no problem.
Polishes are subjective as are the pads
Old Mar 7, 2006 | 03:33 PM
wanabe's Avatar
lotsa good questions and speed bump got most of them...
i will try to get a couple too:
i would not put anything over p21s- at least not right after you apply it. a few weeks later you can put anything you want over it! i find that p21s as the last step gives the best shine. (edit- i just noticed that you were referring to a detailers spray... i dont use a detailers spray as my last step- but a few days later, a synthetic spray over carnuba is fine).
with your polish choice- they are both pretty good and its purely personal. if you try them both, be sure to post up your comparison! i have never done them side by side...
(and i prefer to leave your threads separate- two good topics)
btw, be sure to let any product (including p21s) cure before layering another one on top- each has differing cure times, so read the label- and if the label doesnt say, post up which product and we can give you the approx cure time (cure time is effected by temp, humidity, etc.- so all cure times are estimates).
Old Mar 8, 2006 | 04:59 AM
jmargelo's Avatar
So I will get the Carnuba Spritz to use on top of the P21S after it has fully cured.
Use a duster to make sure the surface is clean between layers of P21S.
Polishes and pads are subjective.
And, I'm still not sure if I should use Klasse Sealant Glaze.
New question: Pad/Applicator/Towel Quantities
What minimum quantity do I need of each of these? I am planning on using a medium and fine polish with PC followed by Klasse AIO, maybe Klasse SG, and a few coats of P21S.
Should I apply the AIO/SG with PC also?
Are Meguiar's MF towels and wool wash mits of high enough quality, or should I be buying something better?
Millions
Jul 11, 2008 08:47 AM
Jaeden09
Jul 22, 2007 07:26 PM
s2000flog
Jul 3, 2005 04:38 PM
romduck
May 16, 2005 07:49 PM
Ap1 type-V
Feb 8, 2002 06:38 PM
