HARD to remove water spots on windows...
Hi all,
I purchased a 2005 GPW that probably had a good rain session and never wiped off and was garaged for years. It has less than 20k miles but there's water stains on the side windows and also some on the front windshield. These spots are the worse my detailer ever has seen and he tried to remove them with his vinegar methods for roughly 2 hours and it didn't help!
I attached 2 pictures but it looks worse in person IMO... any ideas on what methods I should use or what product I should purchase?
Thanks for the recommendation guys, I'll try it out when I get back in town next week
Googled glass polish and this came up...
http://www.youtube.com/watch?v=9znLgZoc2is
He contradicted himself by saying NOT to get it on the paint and then he went ahead and said it was okay to be on the paint
what a professional haha
You want to chemically remove the calcium carbonate and use a non scratching mechanical means of removal. New, clean razor blades work well as do non abrasive pads.
One good last ditch product to use is Bon Ami - original forumula in the red can with "1886" on the label. They make a similiar revamped formula too but it should not be used on glass. Its cheap and works. Make a paste and go for it.
You can find it at Sears, Ace, Osh, etc. Mainline stores have the newer formula. You will have plenty left over to do your appliances and grill.
Another excellent product is called Bar Keepers Friend. It's similar to what cosmomiller recommended, only a finer powder. Always wet the area to be cleaned and follow the directions for use. This works on a whole myriad of materials for cleaning and polishing.
http://www.barkeepersfriend.com/in-the-garage
Just youtube'd it and found this, looks promising! Will try it this upcoming weekend and let you guys know how it goes!
http://www.youtube.com/watch?v=CbYMJD4z1pY
