Help ... Easiest way to clean inside of rear window.
Old Feb 6, 2001 | 04:43 AM
wozman's Avatar
I have used the 3M products on the outside with good results. Although, it appears that I have a hazy build-up on the inside. I don't need to remove scratches on the in-side due to Muz, but just want to get rid of the "haze" as easily as possible (It appears to come off rather easily if I touch the film w/ my finger). Using the 3M products would take too long ... I have a 3M cloth but are unsure what to use. Could I just use windex or a similar cleaning product? Has anyone used a cleaning product on the inside that you can just spray on and wipe off?
Old Feb 6, 2001 | 05:19 AM
wirejock's Avatar
I use Plexus and an old t-shirt. Works very well. Hardest part is turning myself into a pretzel to get at the rear window.
Old Feb 6, 2001 | 05:40 AM
VA S2K's Avatar
Same here, Plexus and a soft cloth or old T-shirt. Basically, use have to kneel down in the driver's seat facing the back to clean the rear window. No other way to do it really
Old Feb 6, 2001 | 01:53 PM
drmark's Avatar
I agree Plexus is the best!
Mark
01/blk/blk#0090
Old Feb 7, 2001 | 07:15 PM
cdelena's Avatar
[QUOTE]Originally posted by VA S2K
[B]...use have to kneel down in the driver's seat facing the back to clean the rear window.
Old Feb 7, 2001 | 07:34 PM
Hoser's Avatar
Ditto, Plexus works great. I use it inside and out. Like everyone says, the hardest part is getting to the window over and around the seats and roll bars.
Old Feb 8, 2001 | 03:34 AM
VA S2K's Avatar
[QUOTE]Originally posted by cdelena
[B][QUOTE]Originally posted by VA S2K
[b]...use have to kneel down in the driver's seat facing the back to clean the rear window.
Old Feb 9, 2001 | 01:36 PM
Mavic's Avatar
Do you work around the wind deflector? That is a pain!
Old Feb 9, 2001 | 01:48 PM
Pinky's Avatar
Fold it down if you can! If you cant then undo the deflector clean and put the deflector back.
Old Feb 10, 2001 | 05:42 AM
BlkS2000's Avatar
[B]Same here, Plexus and a soft cloth or old T-shirt.
