how do I fix this?
Old May 4, 2008 | 10:50 AM
liemha's Avatar
Default how do I fix this?
how do I fix this rip? it's the center console armrest area to the right the the handbreak.
and the tiny rock chip on the headlight
what material do I use where where to obtain them? locally if posible
thanks in advance
Old May 4, 2008 | 12:34 PM
EOE's Avatar
EOE
Leather I am not sure.
Headlights fix in your case because it's chips is Sandpaper. Nothing else will do the job. It might make them clear but not remove the chips. In fact you might have to go really low gritt like 600 and move up because you need to cut in to the plastic pretty deep. Then you work up to 2500 gritt and then polishes and cleaners. Then top it off with sealant & wax.
Old May 4, 2008 | 04:25 PM
wanabe's Avatar
pretty sure that the easiest fix on that leather is to replace that part...
here is a source:
http://ricks2k.com/products/AllLeather.php
they have instructions too
and as eoe says, sandpaper is likely the cure for your lights... check out our how to thread:
how to clear up the headlights:
https://www.s2ki.com/forums/index.php?showtopic=463970
Old May 4, 2008 | 04:52 PM
Millenion LTD's Avatar
clearbra the headlights after polishing
Old May 4, 2008 | 08:24 PM
liemha's Avatar
thanks for leather fix, as for the headlight, how much is the new one run? can I fit the '04-up headlight on my car (2002)
Old May 4, 2008 | 09:46 PM
tekstar's Avatar
if i were you i would just try fixing yours. new ones run more or less 800. hardtopguy.com sells an upgrade kit.
davidc1
Jan 18, 2012 11:54 AM
omgvtec
Jun 20, 2007 07:38 PM
rugsr
Apr 3, 2007 11:44 AM
Ustemuf
Nov 18, 2006 12:13 PM
Sabre
Aug 9, 2006 05:13 AM
