How do I remove cement from paint
I got a little bit of cement splattered onto my paint (I guess from all of the construction around here).
How can I remove the cement without harming the paint.
Thanks,
Dave
Thanks,
Dave
Use distilled white vinegar and a large sponge. Don't wipe!!! Put the vinegar in a bucket and soak the sponge in it. Lay the sponge on the cement spots for 30 seconds then rinse with water. If there is any remaining residue, you can polish it off. Just make sure all of the sand/grit is gone before you do any polishing or wiping. Diesel fuel has also been used.
If those don't work you can try Visual Pollution
Mark
