How to remove brake dust from wheels
Old Jun 20, 2010 | 07:11 AM
Purple Haze's Avatar
Default How to remove brake dust from wheels
Hi, I have a 2006 S. i guess about this time they started using brake pads that really shed dust on the front wheels, it's hard to keep up with the cleaning it's so bad. There are some black spots that won't come off, even with bug and tar remover.
How can I remove these spots? I need an easy and systematic way to keep my wheels clean and shining. Can anyone help?
Old Jun 20, 2010 | 07:54 AM
espelirS2K's Avatar
Try claying them. What bug and tar remover did you use? Might I suggest Stoners Tarminator? It's a very strong tar remover.
Also, what wheel cleaner are you using? Maybe something more powerful will remove the break dust easier
Old Jun 20, 2010 | 08:04 AM
J.W.'s Avatar
Go to Wal-Mart Get "Barkeepers friend" It, water and a little elbow grease will take it of if not its pitted into the metal.
J.W.
Old Jun 20, 2010 | 08:29 AM
DetailDan's Avatar
Stoners Tarminator is a good recommendation. If you can, I would remove the wheels, give them a good cleaning, and apply a sealant to them.
Old Jun 20, 2010 | 07:20 PM
chetly's Avatar
pics of said problem area's? i was really impressed with Sonax, it got brake pad dust off that was caked on my wheels and wouldnt come off with normal washing...
Old Jun 26, 2010 | 02:05 PM
651_ap2's Avatar
And afterwards, buy ceramic brake pads. Makes all the difference.
Old Jun 26, 2010 | 08:23 PM
G's Avatar
G
agree - they dust maybe 10-20% as much.
Old Jun 27, 2010 | 07:41 AM
MikeyC's Avatar
J.W.
Then after that head down to your local Honda dealer and get some new wheels. Bar Keeper's Friend is a scouring powder. It's not meant to be used on painted surfaces which is what S2000 OEM wheels are.
Old Jun 28, 2010 | 06:42 PM
wanabe's Avatar
and dont forget the good old "how to" for wheel cleaning (at the top of the board):
https://www.s2ki.com/forums/index.php?showtopic=420668
Old Jun 29, 2010 | 06:44 AM
akimel's Avatar
I sure have read good things about the Sonax wheel cleaner, available from our sponsor. If I had they kind of brake dust problems that you do, I'd sure give it a try.
But my 2007 doesn't give me the kinds of problems you're describing. I wonder if Honda changed the pads between 2006 and 2007. I use Griot's Wheel Cleaner, which is on the gentle side, and have no problem removing brake dust and stains. Curious.
Another product you might want to try: Amazing Roll Off. I used it last fall to clean the inside of my rims. It did a great job.
