How to tackle this issue?
Old Mar 5, 2009 | 10:48 AM
EOE's Avatar
EOE
Default How to tackle this issue?
Buddy of mine had his Celica repainted and tail lights were smoked. Deet Tee Dee shop smoked them so dark the light didn't even come through when he hit the brakes. He was pulled over on the drive back home and was threatened to be towed if he doesn't do anything about this.
Car was parked and he got some sand paper and went at it. Needless to say the tails have 2 to 3 coats on them, 600 sand parks but not all the way down to plastic.
- How can I remove the spray off the plastic with out sanding them for 10 days straight? lol
- I have Meguairs 105 and 205, that should do the job right? If not Turtle Wax Rubbing compound will come in to play.
Removing the paint?/tint? off the tail lamps looks like the hardest task.
Thanks!
Old Mar 5, 2009 | 10:56 AM
chillout18's Avatar
rubbing compound wont take it off.....I think sanding is the only way
Old Mar 5, 2009 | 11:28 AM
EOE's Avatar
EOE
Oh no I understand. I am asking if there is a spray/product that will take paint/spray tint off with out harming the plastic?
I mentioned Compounds just to let you know I can take care of the sand marks. Just need to know what to do with the tint.
Old Mar 5, 2009 | 11:51 AM
s2k aok's Avatar
bluebat sells overlays (vinyl or something) for the celica and your buddy should have known that prior to having his tails sprayed. the tails are junk now, i wouldn't even bother trying to remove the paint, should've asked newcelica.org prior to doing the project. it's better to ask and feel like an azz rather than not and get punked in the azz...
Old Mar 5, 2009 | 12:04 PM
krshultz's Avatar
I won't swear to it, but my gut tells me that any chemical strong enough to strip paint is likely strong enough to damage the plastic underneath.
Sounds like a trip to the junkyard might be in order for your friend? Toyota made a zillion of those things, I suspect some of them are already in the yards by now.
Old Mar 5, 2009 | 12:19 PM
slanguage's Avatar
If you decide to sand them, wetsand them and use a finer grit sandpaper.
I agree that any paint stripper will probably damage the plastic.
I know this is a dumb question, but are you doing this with the lights on or off the car?
Old Mar 5, 2009 | 01:27 PM
EOE's Avatar
EOE
Off the vehicle. He told me the story. I said let me see what I can do, they just sitting and doing nothing. He is rocking some ugly altezzas right now. EWWWW
He has the rare tails, they came with the action package. They definitely look better then any other Celica rear tails out there.
Instead of
Old Mar 5, 2009 | 04:28 PM
Vanishing Point's Avatar
Try immersing the taillight lense in dot 4 brake fluid. Depending on the paint type and number of coats it could take 4-6 hours to remove the paint. Check frequently to ascertain the progress, use caution when handling the taillight and do wear rubber gloves!
Old Mar 5, 2009 | 08:03 PM
XScarAudio's Avatar
Did you try paint thinner? I painted my tails years ago and used thinner to get a few layers off before re-doing them on the old civic.
Old Mar 6, 2009 | 07:04 AM
EOE's Avatar
EOE
aaah okie will try
e39m5
Jul 4, 2009 06:55 AM
Nick.
Oct 20, 2008 07:30 PM
FOXCONN4
Dec 14, 2006 08:00 AM
BNB
Mar 3, 2006 09:13 PM
dookiewhat
Dec 24, 2004 08:41 PM
