Karcher 330
If you are speaking about the K 330 M which is a k series you will need 2 adapters to work with the foam cannon detailersdomain sells aka the camspray, which you can purchase from pressureparts.com. 22mm x 22m adapter and Karcher adapter A , or you can forgo all of this and buy a different gun with standard adapter fitments that will work out of the box with the camspray. I believe the attachments should also let your k series karcher work with the autobrite foam cannon which is sold primarily in the uk.
I do, my POWER WASHER is like 3,000PSI but with the FOAM CANNON it doesnt allow pressure anywhere near that much, it gets reduced a lot when it goes into the little sponge thing that mixes with the soap, so basically the FOAM CANNON isnt strong enough to blast away all the dirt, which is fine because that would require a lot of force and might damage the paint etc........
efthimios
Dec 9, 2003 12:08 PM
