mezerna order?
Originally Posted by emrillive,Nov 6 2009, 06:51 PM
im sorry which polish is used first? sip or po85rd
Originally Posted by rosscoe21,Dec 10 2009, 02:12 PM
Love those polishes. On my Rio I didn't have to follow with po85rd but I did anyways.
Originally Posted by MikeyC,Dec 10 2009, 02:43 PM
Just keep in mind you may not have to use both. If your finish is in great shape then you can just polish with 85 to really amp up the gloss. If you have swirls you'll definitely need to start with SIP then finish with 85.
Remove worst of swirl areas (sip), overall lighter cut/even gloss with 85, no excess work or polishing
Originally Posted by BlueBarchetta,Dec 10 2009, 07:50 PM
Or "spot treat" particular problem areas with the SIP, then finish with all over PO85rd. 85 seems to have enough cut, with the proper pads, on our paints for most but the worst swirls.
Originally Posted by MikeyC,Dec 10 2009, 04:54 PM
The S2000 does have REALLY soft paint. The PO85RD has almost no cut though so I'm surprised to hear you're taking swirls out with it.
Main point to the OP was similar to yours. You don't always have to use SIP, and even if you do, sometimes you can just correct certain areas, then finish out with po85. Basically do the least amount of aggressive polishing that is necessary.
I'm glad to hear you guys saying that S2000's have really soft paint, but after having detailed 4 of them, I just can't believe it. I've done 2 with really bad swirls, and with the intensive polish, an uber orange pad, and a PC set to speed 6 (finishing on 5), I usually have to go over the same area 2 or 3 times to get the swirls out. On the sides of the car, it's not that bad, but on all flat surfaces, it's going to take a while.
