need help using menzerna sip
first time using menzerna sip and cant figure out what im doing wrong.i used a pc with orange pad on my berlina and i have halograms all over.i spread it on level 3 then tried to break it down on 6 and all i get is haze and dull paint.what should i do?
are you sure they are halograms?
sip should be followed up by a less aggressive polish-
a good choice is this one:
http://www.detailersdomain.com/menzernafin...nishpo85rd.aspx
on a mild cut pad...
you might be seeing "polish haze" which is normal for a more aggressive polish.
Originally Posted by cgutter,Aug 31 2009, 05:33 PM
i do remember polishing till the product was basically dry and dusting...is that to long?
might not be long enough- you polish until dust then inspect. are you polishing in lines or in circular motions?
You shouldn't need to go higher than 5 on the PC.
which pad are you using? Also, moving the polisher too fast can add to the problem.
After you are done with the sip, are you doing a good wipedown?
If so, you are still going to need to follow up with the final polish and a less agressive pad anyways.
Originally Posted by wanabe,Aug 31 2009, 06:16 PM
no- not too long...
Originally Posted by cgutter,Sep 1 2009, 04:00 AM
im using the orange pad and moving about 3 seconds a line..wipedown meaning alcohol or just towel?
i think you can just use a good micro fiber - shake often (thats what i do)
wipe down best if not circular (btw your polish method above looks fine- not leaning on the machine i assume?)
did you "condition" your pads before you began? shouldnt be a big deal- i use a pad conditioner (its a spray), but just about any moisture on a dry pad is fine when you start. for years i did not condition my pads, so its no big deal if you dont... back in the good old days we didnt worry about pad conditioning!
