Permanent Marker
^-- or 50/50 alcohol +distilled water.
get a sharpie and draw on something then use rubbing alcohol and see what happens. itll come off for sure, but swirling might happen if you let it dry. make sure you wash it off right after.
Originally Posted by wanabe' date='Jan 22 2009, 11:16 AM
good suggestion...
i havent used it for that, but use it for just about everything else.
definitely worth trying
says there is nothing in WD-40 that would hurt you.
When you read the "shower door" part, try it.
It's the first thing that has ever cleaned that spotty shower door.
If yours is plastic, it works just as well as glass. It's a miracle!
Then try it on your stovetop ... Viola!
It's now shinier than it's ever been. You'll be amazed.
Here are some other uses:
1. Protects silver from tarnishing.
2. Removes road tar and grime from cars.
3. Cleans and lubricates guitar strings.
4. Gives floors that 'just-waxed' sheen without making them slippery.
5. Keeps flies off cows.
6. Restores and cleans chalkboards.
7. Removes lipstick stains.
8. Loosens stubborn zippers.
9. Untangles jewelry chains.
10. Removes stains from stainless steel sinks.
11. Removes dirt and grime from the barbecue grill.
12. Keeps ceramic/terra cotta garden pots from oxidizing.
13. Removes tomato stains from clothing.
14. Keeps glass shower doors free of water spots.
15. Camouflages scratches in ceramic and marble floors.
16. Keeps scissors working smoothly.
17. Lubricates noisy door hinges on vehicles and doors in homes.
18. It removes black scuff marks from the kitchen floor!
Use WD-40 for those nasty tar and scuff marks on flooring.
It doesn't seem to harm the finish and you won't have to scrub
nearly as hard to get them off.
Just remember to open some windows if you have a lot of marks.
19. Bug guts will eat away the finish on your car if not removed quickly! Use WD-40!
20. Gives a children's playground gym slide a shine for a super fast slide.
21. Lubricates gear shift and mower deck lever for ease of handling on riding mowers.
22. Rids kids rocking chairs and swings of squeaky noises.
23. Lubricates tracks in sticking home windows and makes them easier to open.
24. Spraying an umbrella stem makes it easier to open and close.
25. Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26. Restores and cleans roof racks on vehicles.
27. Lubricates and stops squeaks in electric fans.
28. Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29. Lubricates fan belts on washers and dryers and keeps them running smoothly.
30. Keeps rust from forming on saws and saw blades, and other tools.
31. Removes splattered grease on stove.
32. Keeps bathroom mirror from fogging.
33. Lubricates prosthetic limbs.
34. Keeps pigeons off the balcony (they hate the smell).
35. Removes all traces of duct tape.
36. Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37. Florida's favorite use is: "cleans and removes love bugs from grills and bumpers."
38. The favorite use in the state of New York, WD-40 protects the Statue of Liberty
from the elements.
39. WD-40 attracts fish. Spray a little on live bait or lures
and you will be catching the big one in no time.
Also, it's a lot cheaper than the chemical attractants
that are made for just that purpose. Keep in mind though,
using some chemical laced baits or lures for fishing
are not allowed in some states.
40. Use it for fire ant bites. It takes the sting away immediately and stops the itch.
41. WD-40 is great for removing crayon from walls.
Spray on the mark and wipe with a clean rag.
42. Also, if you've discovered that your teenage daughter
has washed and dried a tube of lipstick with a load of laundry,
saturate the lipstick spots with WD-40 and rewash. Presto! The lipstick is gone!
43. If you sprayed WD-40 on the distributor cap,
it would displace the moisture and allow the car to start.
P. S. The basic ingredient is FISH OIL.
A lot of people don't realize that the solvent that removes permanant ink is the same solvent that is used to keep the marker from drying up. In other words, all you need to remove sharpie marker is a sharpie marker. Just rub over the mark with fresh ink and then wipe it off very quickly with an alcohol swab. It worked great for me.
Isopropyl alcohol will also work.
Originally Posted by slanguage' date='Jan 23 2009, 01:37 PM
um, I vote for clay. The idea of using a marker to get marker off is interesting though.
