Question regarding Menzerna polishes
I'm about to pull the trigger on a pc + polishes just had 1 question on which polishes i should get.
What combo is better, the Menzerna PO203 and Menzerna PO85RD $169+99
(so that i can buy just a regular pc kit + these polishes)
Menzerna Super Intensive Polish and Menzerna Nano Polish PO 106 FA $279
(so I can buy the pc and polishes all in 1 kit)
Any info would be greatly appreciated
tony
tony
SIP is an all around better polish than PO203. The reason I say this is PO203 is more of a "one step" polish. It doesn't get AS MUCH a SIP, but cuts MORE than 106fa, and can finish down better than 106fa (in most cases).
But SIP is better in the long run, because it can have a LOT of cut, mated with an orange pad from DD, or it can only have mild cut, mated with a polishing pad from DD. In the end, it's about personal choice, but I believe you'd be better off with SIP, as opposed to PO203
-Matt
guys trust me you have to try 203 as a 2 step, its going to finish better than SIP so that's why I put it together as a combo with PO85RD...
Matt and espelirS2K try it you will be a believer : )
