Taking Care of 00-01 Plastic window
Old Jan 29, 2007 | 07:50 PM
ohms2k's Avatar
Default Taking Care of 00-01 Plastic window
Ok I heard from people on the forum that they cracked the 00-01 plastic window and i wanted to know how i can prevent this...i heard people talking about putting a cloth in between the folding while the top is down...my question is where does the cloth go exactly?...on the inside of the car where is folds or the outside where it folds? any pics you guys can post with the cloth doing this job while top down?
and also how can i give it that flexibility to prevent the crack?...is 303 aerospace protectant ok?...i know plexus is good for getting the cease out...but is it also good for preventing the crack?
thanks guys
Old Jan 29, 2007 | 08:01 PM
wanabe's Avatar
plexus the window regularly...
roll a rag and place it on the outside of the window as you lowered it.
also, use a muz mat or other soft mat on the inside of the car (shelf where the top lies)
finally, use the boot when possible to provide protection to the top when it is down.
this is what i do, and my top looks brand new after 5 years-
______
the cracking is caused by not taking care of the top or by putting the top up or down when the window is really cold.
Old Jan 29, 2007 | 08:08 PM
ohms2k's Avatar
do you put the rag on the outside and the soft mat in the inside after the top is down?...or its a do it as the top is half way down?
and what do you mean by [QUOTE]finally, use the boot when possible to provide protection to the top when it is down.?
Old Jan 29, 2007 | 08:16 PM
wanabe's Avatar
[QUOTE=ohms2k,Jan 29 2007, 09:08 PM] do you put the rag on the outside and the soft mat in the inside after the top is down?...or its a do it as the top is half way down?
the mat goes on the inside under the window- it is always there. can be velcroed down if you want.
the rag goes on the outside of the window as you lower the top. lower a little bit, get out and put the rag on the window then finish lowering it.
the boot is the cover that goes over the top when its down.
Old Jan 29, 2007 | 08:44 PM
ohms2k's Avatar
ok got you...boot=toneau cover
Old Jan 29, 2007 | 08:49 PM
ohms2k's Avatar
so is the whole purpose to make the plastic not bend all the way ( to the point where it touches itself)?
Old Jan 29, 2007 | 08:58 PM
wanabe's Avatar
correct - to keep it from rubbing on its self and from rubbing on the hard plastic shelf...
and to keep it from folding with a crease.
Old Jan 29, 2007 | 09:08 PM
ohms2k's Avatar
thanks a lot...very helpful information
Old Jan 29, 2007 | 11:46 PM
robs_silver_s2k's Avatar
Oh and don't put it down when it is cold out (near freezing) as that will crach it.
warm up the interior of the car so that it is nice and toasty and then drop it.
Old Feb 3, 2007 | 10:16 AM
dolebludger's Avatar
All advice above is good. Indeed, I don't lower my top when it is below 60 degrees, and never leave the top down and folded very long when I'm not driving top down.
Here's another idea that has kept my plastic window like new for about six years. Mildly clean both sides. Apply 303 Aerospace Protectant liberally and spread evenly with a sponge. Leave on to soak into the pores as long as possible (the warmer it is, the better this works, but it always works.) When you need to drive the car again, wipe the 303 off with a microfiber. It will have smears. Then, clean off the smears with Plexus. Do this once in a while and your window will remain soft -- which means it is resistant to cracking.
