Washing Engine Bay
Old Feb 23, 2018 | 11:20 AM
rpg51's Avatar
Default Washing Engine Bay
Do you guys cover anything in the engine bay when you wash/detail the engine bay? Specifically what do you cover?
Old Feb 24, 2018 | 08:41 PM
trcydaman's Avatar
I cover up the alternator and battery. But I've seen many videos where they don't cover anything and pressure washer everything under the hood without causing any problems.
AmmoNYC has a video on engine bay cleaning. Starts at 3:50.
Old Feb 26, 2018 | 07:49 AM
GSteg's Avatar
I don't cover anything at all. I use a pressure washer so that helps reduce flooding in the engine bay.
Old Feb 26, 2018 | 10:24 AM
rpg51's Avatar
Do you take care to avoid any specific areas with the pressure washer?
Old Feb 26, 2018 | 10:38 AM
jvgough's Avatar
Default ChrisFix
https://youtu.be/PRSoRkM8GcM
Old Feb 26, 2018 | 12:24 PM
cosmomiller's Avatar
Top Answer: 1
All things automotive, in designing and engineering for the engine compartment of cars, it is a given that things get wet from soaked roads, rain spray, and direct water. That does not mean the car can go scuba diving but it can get "somewhat" wet. However, it makes sense not to tempt fate.
I do cover certain electrical items with aluminum foil or plastic wrap (what ever my wife says is okay) such as the alternator, fuse boxes and exposed electrical connections. I also direct spray away from electrical connections.
Old Feb 27, 2018 | 07:10 AM
GSteg's Avatar
I try not to soak the electrical components (battery, alternator, etc) but other than that, spray away. Don't go bananas and use a 15 degree tip with a 3200psi pressure washer. lol.
The bulk of the cleaning should be done with a brush and cleaning solution if your engine bay is really dirty.
Old Feb 28, 2018 | 02:47 AM
rpg51's Avatar
What cleaning solution do you use?
Old Feb 28, 2018 | 07:49 AM
//steve\\'s Avatar
I don't cover up anything either. I've done it dozens of times without any issues. I do usually try to go a little lighter around the spark plug cover, and a little less direct on battery and alternator. They still get plenty wet just not much direct pressure.
Old Feb 28, 2018 | 09:12 AM
GSteg's Avatar
I use Meguiars all purpose cleaner. In reality, most solutions will work because all I'm doing is breaking up dirt buildup. If my engine bay was caked in oil/grease, I opt for Dawn dishwashing soap.
