wd-40
Old Jul 9, 2007 | 10:44 AM
HondaGal's Avatar
kills tent caterpillars in Saskatchewan
Old Jul 14, 2007 | 06:37 PM
01-HMB-S2K's Avatar
#1740 & #1780... I think everyone can relate to those two...
Old Jul 15, 2007 | 06:10 PM
kctheflish's Avatar
Does anyone know the history of WD-40?
Here's a bit of fun reading...
http://www.wd40.com/AboutUs/our_history.html
Old Jul 16, 2007 | 08:51 PM
wanabe's Avatar
water displacement on the 40th try... now thats something not many folks know about!!
Old Jul 17, 2007 | 02:01 AM
kctheflish's Avatar
I happen to be employed by that rocket company mentioned in the article and have used the product by the drum. Boeing developed a similiar product to protect metal as well call Boeshield.
http://www.boeshield.com/index.htm
Both of these can damage rubber so I'd advise caution when using around plastic or rubber on your car. The main design is protect metal. This is done by disolving wax in a solvent. After the solvent flashes off you've got a wax residue covering the metal which helps to seal out moisture.
Good stuff for tools and such, but I'd be careful using on the "S".
Old Jul 21, 2007 | 08:34 PM
TheCarGuy2021's Avatar
I spray it on shovels before shoveling snow. Makes shoveling Cleveland lake effect snow go by quicker and easier. The snow just slides right off. I also use it on plow blades.
Old Jul 22, 2007 | 07:10 AM
jimi's Avatar
Prevents CEL from comming on....
Sometimes my gas cap hangs up. WD works great on the threads
Old Aug 3, 2007 | 08:46 AM
wanabe's Avatar
i just know that i have used that stuff before...
rust prevention as i recall.
can it be used for rust removal??
Old Aug 3, 2007 | 09:43 AM
kctheflish's Avatar
Yep, Both WD-40 and boeshield leave a layer of wax behind after the solvents flash off. So by sealing out the air you help prevent new or slow down existing oxidation.
I think you'll find the solvents help to remove some scalely rust but if you looking to stop rust then I'd recommend a product called "Ospho." We use it all the time at work to deal with rust on the ground support equipment. The launch pads are only a few hundred feet from the beach so salt air tends to cause lots of corrision problems.
http://www.ospho.com/
woodzs
15
May 8, 2009 01:07 PM
S2PIDSTYLE
Sep 19, 2007 11:49 AM
wilken
May 24, 2007 09:27 AM
THEOLDMAN
Mar 26, 2007 12:21 PM
wantone
Jan 19, 2006 03:08 PM
