What am I doing wrong?
In February of 2007, I purchased my s2000 wrecked. My uncle and I rebuilt it in May 2007. I rented a paint booth and, with his assistance, I painted it. It was kind of a learning project.
In June of 2007 I beagn the process of wet sanding the orange peel. The paint looks smooth, but upon close inspection there are hundreds of fine 1/4 and 1/2 inch scratches, and fish eyes here and there. (The fish eyes probably from the the clearcoat not properly curing between sprays)
I have been using a UDM and Meguires #1 light cut compound to work on the paint, but no matter how slow I go and how many passes I make, the fine scartches never go away.
What is a good combination of pads and compounds that will solve my problem?
Thanks.
Thanks.
Originally Posted by HankookS2K,Apr 22 2008, 08:01 AM
what grit are you wetsanding with?What pads are good? What compounds do you reccomend?
Should I just use a basic pad, and depend on the compund to do the work, or should I use various pads?
My buddy who has done several detailing jobs before, says that the paint isn't getting hot enough. He suggests purchasing a rotary buffer. What do you guys think?
if your using a pc for wetsanding its gonna take a LOT of passes to get those scratches out.
I used a rotary on mine. Started with a wool pad with a heavy cutting compound, then a semi-aggressive foam pad with a polish, then a finishing pad with a swirl remover/finishing polish. Then a hand wax. All of the products i use are Car Brite.
I know that meguiars makes a lot of compounds that you can use though, they have a compound called SOLO. its VERY good at cutting, i have used that for wetsanding and it came out great. of course i used a rotary though. I dont think a pc would have enough power to impact the paint. maybe someone can correct me on that though
i really wouldnt start down at a 1000 grit. i would have started at a 2000. 1000 grit will get it REALLY shiny but sacrificing the thickness of the clear. i started at a 2000 grit and it came out perfect!
here is my wetsanding i did on my car a year ago after i got a paintjob.
https://www.s2ki.com/forums/index.php?act=S...0#entry10178056
I guess I will try a rotary next. What speed is good? My buddy has a Snap-On buffer/polisher. 800-3000 rpms.
Thanks.
Originally Posted by HankookS2K,Apr 23 2008, 07:13 AM
so you cleared the car yourself?
That is probably why I have so many fish eyes, LOL.
energetic
20
Oct 26, 2007 04:17 AM
