San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
Looking 4 Eibach/Koni Combo
Old May 19, 2009 | 11:14 PM
Rubn1out4GudLuk's Avatar
Default Looking 4 Eibach/Koni Combo
Hi, I'm looking for anyone else in SD running the Eibach springs with Koni Yellows shocks on their S.
I recently installed the Koni Yellows shocks and noticed that they are too low in the front and rub the fenders way too much. The rears have a 1 finger gap while the fronts have 1/2 finger gap at best. When I sit down in the car, the car gets 1/4 in. lower than that and rubs at times. Bear in mind that this is on the higher perch so I have no other choice to go any higher.
I already matched the part numbers and they are indeed for an s2000. They are also placed in the correct positions/places where they are listed to be installed. The only thing I can think of is that I may have defective shocks or over tightened the nuts therefore having the springs partially compressed at all times hence making it a little lower(especially in the front) than what they were intended to be.
I am calling out anyone that has this similar setup and would like to compare your S's stance to mine. Thank you for taking the time to read this. If there is any useful info anyone can also list that has prior/current experience with these shocks it would also be very helpful.
Nuke
Old May 20, 2009 | 06:12 AM
bradskee's Avatar
Im running eibach springs with koni yellows but theyre coilovers so i dont have a rideheight issue.
Old May 20, 2009 | 06:41 AM
JDMQuip's Avatar
Time to roll your fenders. Lol. J.k.
I wish I could help Nuke. Maybe you have the Konis reversed? Front to back?
Old May 20, 2009 | 07:13 AM
^^ I Installed them where the packaging specified for them to go. The front ones were individually packaged with the L(eft) and R(ight) after the part number to specify which side they go on while the rears came in one package and were not marked at all. I followed the instructions on where they are supposed to go. Something is not right with these shocks. Either they are constantly partially compressed or defective. They are on a higher perch...I had the fronts on the lower perch before and my tires were tucking inside the fenders.
Old May 20, 2009 | 07:19 AM
Daygo S2k's Avatar
Banned
usually the fronts will have more coils on them since they have to support more weight (depending on where engine is), but in our case, we have a 50/50 weight distribution, so maybe that theory can be thrown out? haha
Old May 20, 2009 | 05:22 PM
Rasetsu99's Avatar
Are you sure you installed them and pre-loaded everything before tightening everything down?
Since you think you might have compressed the springs to much, all you have to do is loosen the top hat nuts and the locking nut on the top of the shocks. Make sure you are on a flat surface, and then tighten everything back up.
Old May 20, 2009 | 06:11 PM
^^ I just did that and no difference in the stance. The rears are perfect but the fronts are still too low.
Old May 20, 2009 | 08:37 PM
nico1's Avatar
I have an idea Nuke, we may be able to adjust the ride height.
Old May 20, 2009 | 08:56 PM
^^ Gimme a call Aaron...Lemme know ASAP. Wanna have my car ready before may 30th(Julian/Palomar run)
Jerry_Attric
Sep 12, 2018 12:44 PM
02_s2k
Mar 6, 2011 02:23 AM
SwansS2K
Oct 26, 2006 06:50 PM
pikkashoe
Jan 29, 2006 07:57 AM
luvschnauzers
Jul 22, 2004 02:54 PM
