ACDetailing: 2001 S2000
So here is the final result with my trials and tribulations of super soft honda paint, and trying to get the most possible correction within a time/price limit. After the customer picked up the car, he was very pleased with the work, and I went over with him how the paint was going to look in the sun, and even showed him under my different lights just what to expect (picked it up at night time). I was able to get arounf 95% corrected though..
Exterior
Rims/Tires/Wheel wells were pressure washed
Dressed with Megs HD 2:1
Pressure wash the entire car
Wash with Megs Gold Class soap+Shmitt
Dry with DD Uber Waffle Weave Towel
Clay with Megs Mild Yellow+Megs QD
Wash again
Final combination:
Menzerna SIP+CCS White at 1200-1400-1200 for 2 passes
Menzerna PO106FA+CCS Black at 800-1200-800
Menzerna PO85RD+CCS Blue at 800rpms
Prepsol wipe down
LSP
JETseal109 x2
Eqiuipment
Sony A200
Sony DSC T70
500w halogens
1,000,000 candle light spotlight
3M blue tape
Uber red drying+polishing+glass towels
Metabo
3M Backing plate
CCS 5.5" pads
1850PSI Pressure Washer
Shmitt
Before
After claying 1/2 the hood:
After claying:
Afters:
Didn't want the engine bay detailed, but this is the beast underneath:
As always, C/C welcome!
Aaron
Exterior
Wash again
Final combination:
Prepsol wipe down
LSP
JETseal109 x2
Eqiuipment
Sony A200
Sony DSC T70
500w halogens
3M blue tape
Metabo
3M Backing plate
CCS 5.5" pads
Shmitt
Before
After claying:
Afters:
Aaron
Originally Posted by The Twanksta,Sep 12 2008, 11:07 AM
I am having a bit of trouble on an NSX I am working on right now. When you say two passes, what exactly is your process? Thanks!
ALso, how does the black pad differ from the blue?
Also, the black pad is slightly more aggressive than the blue pad, which is perfect for jeweling the paint to get rid of the slight holograms you are talking about.
Do you have a PC or RO of some sort? The thing with soft paint, that I learned from an incredible detailer in Orlando is that in order to finish out hologram free on a soft clear is to go extremely slow, both working the product in, and speed of the machine. A lot of pros still can't finish 100% hologram free, and have to switch over to an RO in order to make the finish 100%. I still have a PC for this exact purpose, incase I ever run into it.
Aaron
Aaron
I am using a high speed. However, after about an hour of reading on Autopia I came to the conclusion that my po85rd/blue pad SHOULD work. Everyone else was using a black pad, but they are pretty close. So I gave it a shot and tada! This "awesome" detailer in Orlando doesnt happen to be Todd does it?
Hes a good guy, learning a ton from him already. In the end I did get a hologram free finish using my PO85rd/blue pad.
