Sparkplugs
Old Nov 18, 2010 | 05:07 PM
Robert O's Avatar
Default Sparkplugs
Just finished a valve clearance inspection on my 06' with 45,000 mi. A few were about .002" out of spec in the loose direction.No big woop. Anyway ,thought I'd throw some new plugs in there while I was at it. The old ones didn't look bad at all and were within gap range. But what hell,I'll throw in a new set anyway.So,I call around parts stores looking for the recommended NGK plugs and of course noones got them in stock.So I order a set of four and the Napa guy says these plugs are 13 dollars and change each. Holy firestorm batman! What are you guys paying for these plugs? Most of the parts stores here can't even get the Nippon Denso alternate plug that is listed in the manual.
Old Nov 18, 2010 | 05:15 PM
importkid's Avatar
Sounds about right. You are getting Ngk laser platinum correct?
Old Nov 18, 2010 | 05:18 PM
Robert O's Avatar
Yup. Plug # PFR7G 11S. Expensive little muthas.
Old Nov 18, 2010 | 05:21 PM
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The plugs in the car are better than anything you can buy in any parts store.
If you buy the exact NGK number from auto parts, the gap will be about .030.
If you buy them from Honda in the red box, the gap will be .039. where it should be.
Adjusting the gap of a platinum plug will fracture the coating, it will fall into the engine, and score the cylinder.
NGK tailors a plug specific to the s2k, for honda, and is sold in a Honda box.
Old Nov 18, 2010 | 05:22 PM
importkid's Avatar
Supposedly they last 90,000 miles though. 50 bucks in plugs that need changing after 4 or 5(maybe more) years is a small expense. Do not gap them.
Old Nov 18, 2010 | 05:23 PM
Top Answer: 1
Originally Posted by importkid,Nov 18 2010, 09:22 PM
Do not gap them.
Bingo
Old Nov 18, 2010 | 05:26 PM
TyFoxx0608's Avatar
Laser platinum? I always thought the S came with denso iridium so couldnt you replace them with NGK iridiums? For my old car RSX-S I think the plugs were about 45-55 bucks for a set and they were the NGK iridiums.
Old Nov 18, 2010 | 05:27 PM
Robert O's Avatar
Well hell,I'll have to bring my feelers with me then down to Napa tomorrow morning when these things come in. If they're not gapped to .039 or .040 then I should walk? The order guy assured me that the NGK number I listed will be printed on the plug.
Top Answer: 1
MOST s2ks come with ngk.
I have found about 0.5 percent of them come with denso.
Old Nov 18, 2010 | 05:30 PM
Top Answer: 1
Yes the number will be on the plug, and read identical.
Bring your feeler
all plugs should be CHECKED for proper gap to ensure they have not been dropped.
Then go to Honda and measure a honda plug
