Show me your aftermarket gauges
Old Jul 4, 2017 | 04:04 AM
har-vey's Avatar
Default Show me your aftermarket gauges
Hi All
I want to install some aftermarket gauges but am unsure on where to mount them. Where have others installed them?
A piller - Guessing you can only install 2 and would it reduce visibility?
Drill into radio door but have to relocate radio
Drill into dash - scares the crap out of me.
Ideally i would like to run
Oil Temp
Oil Pressure
Air/fuel ratio
Boost
Is there a smarter option to possibly have a digital gauge that displays all the information?
Any information would be much appreciated
Old Jul 4, 2017 | 04:39 AM
nomadicS2k's Avatar
The a-pillar ones are pretty good - but finding pre fab one is hard - there was a group buy 6-7 years ago - mine is long gone. Had an oil pressure gauge and an AEM serial gauge .
If you get the slim digital gauges you can fit them in the door like the Ricks. I can't remember the make of the original gauges - Nordskog Street Series digital they were awesome - these look similar
Depends on the ECU you are running - but you can get a windows tablet or something - and fit a JDM bezel like this one. This is the one I prefered as it then gave you full access to the ECU too.
Old Jul 4, 2017 | 04:54 AM
Chuck S's Avatar
Problem with cobbling the dashboard is whatever you put in there is already obsolete.
I think I can see most of what you're interested in via a small iPad which can be mounted several places and not ruin the interior. My interface is via my FlashPro but ODB2 interfaces are common.
-- Chuck
Old Jul 4, 2017 | 05:06 AM
Mr-T's Avatar
I like the idea of a tablet or larger screen, but with an already small cabin and nowhere to really mount it without cutting dash etc... think A-Pillar will be best bet.
Old Jul 4, 2017 | 05:14 AM
Nottm_S2's Avatar
I've gone on top of the dash for now in a small (dual) pod. Will post a pic later.
you can combine OT/OP in one gauge (spa do one) tho i went OT/CT which i may now regret...
i didnt bother with boost as i can check in logs but not seen any belt slip so far
i dont think odb2 works on your aemv2
AJ did the windows tab.. it does look cool
sos so an a pillar one but delivery is ££
https://www.scienceofspeed.com/index...and-drive.html
Old Jul 4, 2017 | 05:36 AM
Mr-T's Avatar
Anyone have experience with GaugeART?
https://gaugeart.com/product/gaugeart-can-gauge/
Expensive, but guess it combines a lot of gauges into one.
Old Jul 4, 2017 | 05:53 AM
har-vey's Avatar
Assuming oil temp and pressure can be wired into the AEM EMS Series 2 any small tablet would be the best bet. Just need to plug it in as and when desired. Is there any Apps that work with the AEM to give a clean gauge like interface?
Old Jul 4, 2017 | 06:09 AM
lovegroova's Avatar
Look at the Modifry dash mount here - minimal amount of cutting and a nice neat install. The mount would easily work with a larger tablet - you just need the right Brodit mount - here's one for an ipad mini: https://www.amazon.co.uk/Brodit-Passive-Holder-Swivel-Retina/dp/B00HVBC00E/ref=lp_1776802031_1_3?srs=1776802031&ie=UTF8&qid=1 499177266&sr=8-3 and here's the whole range: https://www.brodit.co.uk/
You can see my phone with lots of gauges showing (using Torque) in this video:
Old Jul 4, 2017 | 06:17 AM
har-vey's Avatar
https://www.youtube.com/watch?v=xcye6v5pRLE
Thanks LG this is exactly what i would like.
Anyone know if there is some thing like the Torque app available for the AEM EMS?
Old Jul 4, 2017 | 06:58 AM
Mr-T's Avatar
I guess the question would be, what is needed to use a phone and app to read data from the ECU. To my knowledge, currently no apps to link up with the AEM.
