which better swaybar vs. Xbrace
Originally posted by PedalFaster
I'm guessing from your questions that you're relatively new to autocross, in which case, I have to give you the stock advice -- go drive
Steve
Steve
I'm also with the guys that said to go with the bar. Once you get the Kumho's and loop it a few times you'll want one.
Thermostat - This thermostat has the operating temperature set lower than normal. It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving. The use of a flow-control-type valve prevents hunting, thereby achieving rapid stabilization of the water temperature (the engine warms up within a short period). Operating temperature: 68
