*~SWIFT~* Coilover Spring UPGRADE *~SWIFT~*
Swift Metric REPLACEMENT Coilover Springs
CUSTOM SPRING RATES for those either TRACKING their S2000 or for those who are LOW and want to stiffen their current coilover to not "bottom-out" the car.
Swift Custom Coilover Springs are the perfect choice to fine tune your vehicle from the ultimate street car to a full out race car. Not only are these springs superior in brand but are the lightest, most durable, and provide the most linear spring rate on the market. Period!
While most track racers have already began the ritual of swapping their springs, many swap from one brand to another let you notice the stiffness only as being either softer or harder. What if a spring could change other dynamics, such as a noticeably lighter unsprung mass, smoother weight transferring, better ride quality, lower tire temperature, and increased ability to anticipate vehicle reaction? Like most racers, Swift team hates to hear “what if”, so they built the “what if” into reality.
All of the Swift Springs are made with there exclusive material called H5S.TW. Without this specially designed material, there light weight spring design could not exist.
Will work on All aftermarket coilovers which use a linear 60mm | 65mm or 70mm spring.
BC Racing | Fortune Auto | Tein | HKS | Buddy Club | Stance | KW Suspension | D2 | ST | KSport | Bilstein | Megan Racing |
Example: Swift Coilover Springs on Fortune Auto Coilovers:
Swift 60mm 4 Inch Coilover Springs
Swift 60mm 5 Inch Coilover Springs
Swift 60mm 6 Inch Coilover Springs
Swift 60mm 7 Inch Coilover Springs
Swift 60mm 8 Inch Coilover Springs
Swift 60mm 9 Inch Coilover Springs
Swift 65mm 4 Inch Coilover Springs
Swift 65mm 5 Inch Coilover Springs
Swift 65mm 6 Inch Coilover Springs
Swift 65mm 7 Inch Coilover Springs
Swift 65mm 8 Inch Coilover Springs
Swift 65mm 9 Inch Coilover Springs
Swift 65mm 10 Inch Coilover Springs
Swift 65mm 11 Inch Coilover Springs
Swift 70mm 6 Inch Coilover Springs
Swift 70mm 7 Inch Coilover Springs
Swift 70mm 8 Inch Coilover Springs
Swift 70mm 9 Inch Coilover Springs
Swift 70mm 10 Inch Coilover Springs
