excessive heat under hood
Am receiving excessive heat under the hood. My coolant temp is sub 190s on average. I'm running a 6266 precision turbo. I was running on q16 am now retuning on E85
Driving around for about 15 min then to open the hood there seams to be an extreme amount of heat.
I have considered modifying the hood for vents. Anyone have any ideas on how to cut down under hood temps? I have some concerns with the amplitude of heat.
I use to have that issue. My hood would get so hot you could literally cook food on it. I bought some fiberglass reinforced stick-on heat shielding from amazon. Put it on my shock tower and on the bottom side of the hood. That stuff is amazing. My hood stays cool now.
That and DEI exhaust wrap on the manifold and dp and I have zero heat issues. My rad fans have no issue keeping the coolant temps at 189 and below
Project S2000: Part 23. Testing Air Temps Through Coolers and Vents
Engine temp was one of the reason why I went with pfab topount instead of front mount. Less surface of the turning manifold.
Here is the stuff I used. I highly recommend it. I've had it on for about a year now and none of it has come unstuck.
The pic I do have you can see where I covered the shock tower to save my shock from absorbing all that heat.
If your budget allowed then I would recommend the Mugen, J's or Spoon hoods with pre cut vents that are stylish and functional. If not those then you could go the stock hood cutting route like many have done before. Heat wrapping as many of the heat producing components as possible coupled with a vented hood would work wonders for cooling.
Currently the headers have been coated internal and ceramic coating on exterior along with heat wrapping. i am using a heat spacer to the intake manifold. Radiator is a mishimoto with dual fans. There is also a carbon fiber front shroud cover of which i have been considering removing.
i have verified that coolant is flowing properly through the engine.
What i mean by excessive heat is its dramatically hotter then most turbo vehicles i have worked on. its hotter then some cars i have ran on my dyno for a number of hours vs driving this thing for 15-20min around the block with no boost.
I am also considering an oil cooler.
