Ballade TCT Spring Compatible to OEM Spring???
Hi!
To clarify: Can I use OEM TCT spring with Ballade Sports TCT
I was servicing my Ballade Sports TCT when all the internals (pins, corkscrew, springs) popped out of the engine when I pulled out the TCT body. Subsequently I lost the big spring, the one that pushes the piston against the TCT body. Is this spring specific to the Ballade Sports TCT or would I be ok to replace with an OEM TCT spring?
Ballade is no help? That's surprising.
I'd look harder. Unless you did this in the dark in a meadow or on the beach the spring is under the hood or somewhere in your garage or driveway. Or, if you have the OE TCT put it back on and later send it to Billman and get his GenX TCT and not be bothered with "servicing" this again.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
