Transmission Won't Come Out
Hey why my s2000 transmision don't come out please help
All bolt are out 8 from transmision 1 from the started master clutch off
The transmision is like lil open from the bottom I can see the clutch and the flywheel
Pls help help help I want to drive my s2k this summer
Ian300D (03-18-2019)
^ These two have nailed the main sticking points. The other will be you need to lower the front subframe by a couple inches. Also if this is your first time a good nights rest and proper lighting can really illuminate things. Good luck.
S2k transmision Killing me
I have stage 3 clutch and 8 lb flywheel sitting down waiting that transmission going out
Fork out
Now I feel like I want troll out this car I'm angry as f***
All transmission bolt out
Are you sure you are not getting caught up on the shifter mechanism? It is fully apart and not in the way?
Some mentioned lowering the engine and subframe, which you should. But you likely did if you have all the trans bolts out. But just in case, there are two bolts you cannot get out or even get to well unless you have dropped the subframe a few inches. It appears you have done that from the pics though.
And to ask the very obvious, you have removed the trans supports and drive shaft, correct?
Otherwise it should come right out. Mine was out in about 3 hours when I replaced my clutch.So I assume there is just something interfering you are not seeing.
