Lightest weight track wide (9.5 to 10.5") wheels available (13.8 to 15.3 lbs)
Even at 18", lighter than 17" options by 2-3+ lbs per wheel, plus 18" tires typical weigh a little less than 17" (less sidewall) for 3-4+ lbs per wheel/tire savings
Lighter than typical 18's by 5+ lbs per wheel.
Widest wheels for OEM S2000 fenders and +1mm over fenders (every 1" of wheel width is worth ~1 sec per 2 min track time)
18" wheels support S2000 25" diameter better than 17" (worth an additional ~1 sec per 2 min or track time)
Maximum BBK clearances
Magnesium has incomparably high dampening factor with noticeably less NHV than Aluminum wheels
Made by an OEM wheel supplier
3 Size options
9.5" high offset (13.8 lbs) to fit front OEM fenders ($1350 per wheel)
10.5" high offset (15.3 lbs) to fit front OEM fenders ($1400 per wheel)
10.5" higher offset (14.6 lbs) to fit rear OEM fenders ($1400 per wheel)
Note, magnesium wheels are typically >$2000 per wheel, we are going straight to an OEM manufacture and working on lower margins to provide these prices.
5 great combos to fit common S2000 needs
9.5" front and rear, OEM fender fitment, front to rear tire rotation
How about other shapes and 17 inches? I remember you guys used to sell the 17-inch.
We can provide a great deal on 17" Aluminum wheels.
There are not available 17" Mag wheel forging at the wider diameters.
Additionally, 18" wheels have proven to be faster than 17", even on lower HP cars.
@Urge would you guys be interested in a new alloy? Stronger and lighter than aluminum, cheaper than titanium.
Davy Industries
they are making their mark in the power sports market with wheels, suspension, and roll cages. Rhys Millen will be running in the Baja 1000 with their stuff this year. Looks promising
