Naperville, IL Silverstone S2000, Supercharged, 94,800mi
Naperville, IL, 2004 Silverstone S2000, Supercharged, 94,800mi
First Name: Brandon
Price: $29,900
Contact: bsbates03@gmail.com
Supercharged 2004 Honda S2000 in excellent condition. Purchased in stock condition in 2016. Meticulously maintained. No expense spared to bring car up to modern performance/reliability standards. Full engine rebuild and supercharger install was performed at 82,000 miles, including upgraded valvetrain. All work/maintenance performed by ILL Garage in Addison, IL. All records available. Ohlins DFV coilovers. e85 and 93 octane tunes, currently on 93 map. Passes emissions. 300 miles on new clutch. New OEM motor mounts. I never tracked the car.
Full parts list:
Engine/ECU/fueling
engine rebuild at 82,000
Kraftwerks supercharger system
ID1300x injectors
Aeromotive 340LPH fuel pump
oSupertech dual spring/titanium retainers/keepers and seals
oSupertech intake valves nitride
oSupertech inconnel exhaust valves
oSupertech bronze exhaust guides
oResurfaced cylinder head mating surface
o9 angle performance valve job
New OEM F22 pistons
New OEM piston ring set
New connecting rod set
ACL race bearing set
Bore/honed alloy block
Poished crank
New OEM chain
Ballade sports TCT
New spark plugs, coils
New oil pump assembly
ARP head studs
Hondata Kpro ECU
o93 octane map
oE85 map
o4 bar map sensor
Koyorad radiator
Mishimoto radiator hoses
Upgraded thermostat
Transmission/clutch
AP1 flywheel
Competition stage 4 clutch (300 miles)
Suspension
Exhaust
Skunk 2 alpha series header
Berk 3 inch stainless exhaust
Wheels/tires
Enkei rpf1 17x9 +45, black,
Continental extreme contact
Brakes, installed at 80,000 miles
PowerStop Brake calipers, red
StopTech slotted rotors
Exterior
OEM AP2 front lip
OEM AP2 trunk lip
JDP Carbon rear diffuser
Carbon side skirts
Professionally applied Ceramic coating
Price: $29,900
Full parts list:
Engine/ECU/fueling
ID1300x injectors
New OEM F22 pistons
Poished crank
New OEM chain
Ballade sports TCT
ARP head studs
Hondata Kpro ECU
o93 octane map
oE85 map
o4 bar map sensor
Koyorad radiator
Upgraded thermostat
Transmission/clutch
AP1 flywheel
Suspension
Exhaust
Wheels/tires
Exterior
OEM AP2 front lip
OEM AP2 trunk lip
Carbon side skirts
NSXPhil (05-16-2024)
Jaylom
Cars for Sale
04-18-2022 05:06 PM
outerorbit1
Cars for Sale
06-01-2019 03:18 PM
