Sponsored by:
Sponsored by: Sake Bomb
Offset bushing torque help
Old Jun 5, 2026 | 10:48 AM
2soonjr.'s Avatar
Default Offset bushing torque help
I found a few threads on this but wanted to get new feedback from people if there is any. I installed the delrin offset upper control arm bushings on my car and am installing the arms now. I greased the shit out of the outside of the bushings and the washers with mobil1 grease and now some marine grease; when torqued to the factory 75ftlb, the arm is immobile by hand and when compressing the suspension with a jack, it moves but is then barely collapses back down.
Would it be okay to run a lower torque spec, around 55 ftlbs here? Or am I using the wrong kind of grease? I understand that with the hub, brakes and wheel attached the weight would be enough to move it but it seems way too stiff
Old Yesterday | 09:55 PM
JBamin's Avatar
contact origin fab. he will tell you if you did not do something correctly during your install. https://originfabrication.com/
Old Today | 08:26 AM
Bullwings's Avatar
Check the 6:00 minute mark. The arms will not move around loosely. It looks like he applies a decent amount of force moving them back and forth - but they do move freely along the range. Does your look like this?
Edit: just to add - i've done this mod myself as well. The arms moved like the ones in the video. They definitely required some effort to move up and down, but I could do it with my own strength - unassisted by tool providing mechanical advantage.
MPower13
Jul 6, 2022 09:33 AM
DefSport
Sep 15, 2017 01:28 PM
dmw16
Apr 5, 2007 12:29 PM
walter_s
Mar 6, 2005 12:42 PM
