Clicking on Photo's problem
Originally Posted by yogi.member,Jul 28 2004, 11:32 AM
The login/logout red X problem isn't a permissions problem, the site was probably just under heavy load.
Here is the page with the pics https://www.s2ki.com/forums/index.php?showt...0&#entry4260108
Karim
I think it's just a traffic issue. There is nothing in the code that differentiates between a guest and a logged in user. If it's consistent throughout the day, then it might be a real issue, although I have no idea what could be causing it.
Yogi here is another update on it. Last night when I tried it with and put up that post it was around 11:30 PM pac time. I then triedagain this morning from work and still no go unless I'm logged in and now again the same thing so it is consistent though out the day.
The other thing I noticed that it's only pics hosted on s2ki that this happens to. If the picture is hosted on another site it comes up fine Example in the post I posted above https://www.s2ki.com/forums/index.php?showt...0&#entry4260108
When I'm logged out and looking at that post the ones I posted which are hosted on my s2ki album become red x's but the ones NOIPS2000 posted which are hosted on his site work perfect. When I'm ;pgged back in they all work fine.
Also when I'm logged out and click on the pic to see the full version it gives me this error message
"Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
Sorry, but you do not have permission to use this feature. If you are not logged in, you may do so using the form below if available."
Once again works fine when I'm logged in.
Hope this helps and best of luck,
Karim
Karim
I'm about to crash, will look into it in the morning.
