Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
<CR> after insert photo?
Old Apr 21, 2005 | 07:52 PM
ruexp67's Avatar
Default after insert photo?
I see at least three posts a week where someone has 3-20 pictures scrolled off the screen. Can you add a <CR> to the end of the insert photo code so that it will, by default, add the pictures down?
Example (BAD):
ABCD
Example (Good):
A
B
C
D
*Pix removed for simplicity*
Old Apr 22, 2005 | 08:54 AM
cthree's Avatar
Administrator
Your examples look exactly the same to me Your using IE6 I suppose. Ie has a table width bug they never fixed. The images should wrap within the width of the table cell just like text does. IE seems to push out the width of the table instead. The images are "inline" meaning they should wrap within their containing block. IE doesn't see images as separate wrapable elements: It sees:
Code:
<img/><img/><img/>
as "abc" not "a b c". No word break. Try your example with a space between the images and see if they wrap. I may only need to add a space to resolve it.
Old Apr 22, 2005 | 10:27 AM
ruexp67's Avatar
Yep, IE6 and yep a simple space between them worked fine.
*I'll remove the pix from the first post as they are not necessiary anymore*
Old Apr 23, 2005 | 04:45 AM
freq's Avatar
Good call ruexp.
Now if we can get the quote feature worked so that images don't appear in quotes............................................ .........................
The world will be a better place.
Old Apr 23, 2005 | 11:22 PM
AquilaEagle's Avatar
Administrator
Old May 8, 2005 | 12:32 PM
ruexp67's Avatar
So, is this going to happen?
Old May 8, 2005 | 01:50 PM
cthree's Avatar
Administrator
should be done?
Old May 8, 2005 | 02:08 PM
Administrator
Seems to work fine now
Old May 8, 2005 | 02:30 PM
ruexp67's Avatar
Nope, not for me. Still side-by-side.
No space insert or CR.
Old May 8, 2005 | 06:30 PM
Stratocaster's Avatar
I agree. With IE it is still fubar'ed
