Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
How to do a Multiple upload to Photo album
Old Sep 13, 2004 | 02:42 PM
  #21
yogi's Avatar
Originally Posted by Elistan,Sep 13 2004, 01:00 PM
Yogi, many thanks for implementing this feature - it was greatly needed!
However, I'm having an issue with it that hopefully you can figure out. I created a new album last night and used the new interface to drop in a new picture. Everything worked, so I dropped in some more, and again got the "Done!" result without issue. However, none of those subsequent images show up in the album. I still have that one image, and no more. The really werid part is that the album information shows that 158 pictures are in it. (I re-tried quite a lot.)
Is there some issue with using the multiple-picture-upload on the same album more than once?
Thanks!!!
Is it a private album? I don't see any issues on the public ones. I just tried and it seems to work fine. When you dropped in the second set of picutres, did you get a
Code:
Adding image "S2000_engine.jpg"...
Type of message for each filename (obviously not S2000_engine.jpg, that's just an example)? If it did, you may have found the first bug! Send me the name of the album so I can poke the database and see if it's confused.
Old Sep 13, 2004 | 02:51 PM
  #22
yogi's Avatar
[QUOTE=markiem8,Sep 13 2004, 12:35 PM] I'm still stupidified
Old Sep 13, 2004 | 03:03 PM
  #23
markS2kcU's Avatar
Hi yogi.
My popup box looks the same size as the one you posted, inside it its a gray colour with no writing, I don't get any other popups.
I have tried it with all Norton turned off and it was still the same, I guess I have not got java installed on this computer
Where can I get java from?
Ps. while I'm still typing I cant activate my s2k email?
Cheers
Old Sep 13, 2004 | 03:33 PM
  #24
markS2kcU's Avatar
Doh, turns out I didn't have java
Uploads are sorted now
Email would be nice
Old Sep 13, 2004 | 06:27 PM
  #25
Elistan's Avatar
Code:
It used to be private, but I've made it public now. It's album number 11804. There's only one picture in it that I can see, but the stats on it show 158 of them. I was trying to upload 53 pictures, and initially doing them all at one, I didn't get any confirmation. So I tried one. It worked. Then two. That worked. Etc etc all the way to 10 at once. Those all got confirmation notices as well. But only that one, singleton upload is viewable...
Thanks again!
Old Sep 13, 2004 | 07:28 PM
  #26
yogi's Avatar
Yea that is weird. How large was the folder of 53 images? It'll take some time after the upload progress window closes. It takes a few seconds per megabyte, so 53 images would be a few minutes. Give it some time and wait for it to output something. If it doesn't after awhile, lemme know, something is ed. I'll try with a big chunk of images in a lil bit.
Old Sep 13, 2004 | 07:37 PM
  #27
yogi's Avatar
I fixed the image count on that album, but that doesn't fix anything, so do what I said above.
Old Sep 13, 2004 | 08:08 PM
  #28
Elistan's Avatar
It' 4.65 MB total. I'll give it another go right now...
Old Sep 13, 2004 | 09:21 PM
  #29
Elistan's Avatar
I never got a confirmation message, but everything appeared to upload without issue. Hmm, dunno what happened.
Sure is a hell of a lot easier than doing the pics one by one, though!
Old Oct 11, 2004 | 04:48 PM
  #30
oatnet's Avatar
Hmm... When I try to do this, I get a little white window, with a red-X box in the upper left corner. Properties of the X are:
"https://www.s2ki.com/forums/index.php?act=upload&album=7659"
When I drag a range of pictures to it, the last picture appears in the box. When I drag a folder, the filenames in the folder appear in the box. Nothing uploads though!
I am running IE 6 on XP pro.
-JD
