Multiple Image Upload
Or is it just me?
WTF am I doing wrong, or is it the site itself? |
It's never worked for me. :rev:
I heard a ancient stories from the elders that it used to work.
It works fine for me, and it did last night :rev:
make sure you have Java installed, and click yes on the prompt. Check what it says in the little box, it describes maximum limits etc :drunk: |
Once I open up the MIU box, the box is blank mind you, I drag .jpg files into the box and the images show up in the box, it seems to work that far. After I am done doing that what do I click next to complete the operation? The upload image button?
First, make sure your browser can do java applets. If it can't then the multi-upload feature won't work. We use 2 Java applets on the site, one is for the multifile upload, the other is for chat.
When you click multiple file upload it will display a popup window. If it's the first time you've used it it will give you a security notice first. Click yes. The popup window will have some instructions. Drap the files you want to upload onto this popup window and you'll see a progress monitor window come up as it sends your files. When it's complete the popup window text will change saying they were uploaded. Don't close the popup until after it says it's all finished. |
I had to update Java to the current version. After that, it's worked like a charm.
Is this a java issue on your system? Does the chat function work for you? You should have Java 1.4.2 I think, I'm not a java guru. Mine just seems to sortof work without installing anything or getting too involved. I had some trouble using Java applet under firefox 0.8 but they have been working fine since 1.0 came out. Please provide browser info (software & version). |
Mine worked fine last week
I have Internet Explorer (Version: 6.0.2800.1106) and it doesnt work as well. :(
