Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
profile menu wont go away!
Old Apr 18, 2011 | 01:23 AM
user 192245235243's Avatar
Banned
Default profile menu wont go away!
for some reason the drop down menu top right of my screen wont go away, i constantly have on my screen the menu "my profile, my settings, my content etc). how do i get rid of it??
Old Apr 18, 2011 | 04:37 AM
cthree's Avatar
Administrator
This is a problem with your browser not the site. It doesn't happen to anyone else.
Old Apr 18, 2011 | 08:43 AM
Ludedude's Avatar
Administrator
Are you using any sort of script blocker like NoScript or similar?
Old Apr 19, 2011 | 12:33 AM
Banned
i use google chrome and this happens, only on this site, every other site i go on works perfectly. just loaded up into IE and this site works fine too. does s2ki not like google chrome?
Old Apr 19, 2011 | 01:14 AM
energetic's Avatar
I'm using Google Chrome as my primary web browser and it works fine with no issues. I've tested this also in Safari, Firefox, Opera and IE and there is no issue. Are you sure you click elsewhere, once the drop down menu pops up? If you open it, and don't click elsewhere it will stay open, even if you scroll the page up or down; this is normal.
Old Apr 19, 2011 | 03:38 AM
cthree's Avatar
Administrator
It works fine with chrome. Turn off your extensions and you'll find the culprit. Start with ad blocking plugins.
Old Apr 20, 2011 | 02:09 AM
Banned
i dont have any plugins installed that look like they would stop the menu from working. i've even turned them all off and its still not working
Old Apr 20, 2011 | 07:42 AM
cthree's Avatar
Administrator
Does the page load with the menu open?
Are there any Javascript or other errors reported by the browser? You can see by opening the developer tools panel (view -> developer -> developer tools on my Mac) and selecting Console and then Errors.
Navigate to any page where the menu is open and then open the error console (see above) and if you see anything listed please copy them to this topic. You should not see anything listed under Errors.
Old Apr 20, 2011 | 01:23 PM
Banned
yeah the menu is there as soon as i load the page up. yeah loads of errors!
Uncaught TypeError: Object function Event() { [native code] } has no method 'observe'
scriptaculous.js:53Uncaught script.aculo.us requires the Prototype JavaScript framework >= 1.6.0.3
ipb.lang.js:1Uncaught ReferenceError: ipb is not defined
www.s2ki.com:121Uncaught ReferenceError: ipb is not defined
www.s2ki.com:173Uncaught TypeError: Cannot call method 'boot' of undefined
www.s2ki.com:237Uncaught ReferenceError: $ is not defined
www.s2ki.com:294Uncaught TypeError: Object #<HTMLDocument> has no method 'observe'
www.s2ki.com:360Uncaught ReferenceError: ipb is not defined
www.s2ki.com:551Uncaught ReferenceError: ipb is not defined
www.s2ki.com:576Uncaught ReferenceError: $ is not defined
www.s2ki.com:706Uncaught ReferenceError: ipb is not defined
www.s2ki.com:729Uncaught ReferenceError: $ is not defined
www.s2ki.com:855Uncaught ReferenceError: ipb is not defined
www.s2ki.com:878Uncaught ReferenceError: $ is not defined
www.s2ki.com:998Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1027Uncaught ReferenceError: $ is not defined
www.s2ki.com:1149Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1172Uncaught ReferenceError: $ is not defined
www.s2ki.com:1290Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1313Uncaught ReferenceError: $ is not defined
www.s2ki.com:1433Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1462Uncaught ReferenceError: $ is not defined
www.s2ki.com:1584Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1607Uncaught ReferenceError: $ is not defined
www.s2ki.com:1637Uncaught ReferenceError: $ is not defined
www.s2ki.com:1665Uncaught ReferenceError: $ is not defined
www.s2ki.com:1708Uncaught ReferenceError: $ is not defined
www.s2ki.com:1961Uncaught ReferenceError: ipb is not defined
www.s2ki.com:1986Uncaught ReferenceError: ipb is not defined
www.s2ki.com:2173Uncaught ReferenceError: $ is not defined
www.s2ki.com:2185Uncaught ReferenceError: $ is not defined
www.s2ki.com:2259Uncaught TypeError: Object function Event() { [native code] } has no method 'observe'
lightbox.js:18Uncaught ReferenceError: Class is not defined
www.s2ki.com:2328Uncaught TypeError: Object function Object() { [native code] } has no method 'extend'
16Unable to post message to http://googleads.g.doubleclick.net. Recipient has origin https://www.s2ki.com.
Old Apr 24, 2011 | 09:38 AM
cthree's Avatar
Administrator
What version of Chrome are you using? Also, clear your cache to be sure it's not using a cached versions of those javascript libraries
