Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
Site Error
Old Nov 27, 2004 | 06:52 AM
JAHumphrey's Avatar
Default Site Error
I get the following error when I try to load the S2KI home page:
mossession::store failed
DB function failed with error number 1114
The table 'mos_session' is full SQL=INSERT INTO mos_session ( `session_id`,`time`,`guest` ) VALUES ( '3f24543df7a6cc30b66d4f89bcc357ec','1101570674','1 ' )
What ius this all about?
Thanks!
Jamie
Old Nov 28, 2004 | 12:49 PM
AquilaEagle's Avatar
Administrator
Maybe it is because your signature is so big, can you reduce it in size please.
Thanks
Old Nov 28, 2004 | 06:54 PM
JAHumphrey's Avatar
Yea, that must be it.
Works great now!
Old Dec 7, 2004 | 02:10 PM
dreamcation's Avatar
Thumbs up
I got it to
The table 'mos_session' is full SQL=INSERT INTO mos_session ( `session_id`,`time`,`guest` ) VALUES ( 'bdbff4648d5a9fbad143c40177b1a33b','1102460796','1 ' )
Old Dec 7, 2004 | 03:28 PM
azndrunkyoon's Avatar
yea i got it witout a signature
Old Dec 7, 2004 | 09:59 PM
Administrator
maybe it was someone elses
Can you give some more info - what were you trying to do when the error came?
Old Dec 8, 2004 | 03:24 PM
I got that error when I search for www.s2ki.com
The problem is how ever fixed today
Old Dec 9, 2004 | 04:29 AM
rbackhouse's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
"The table 'mos_session' is full". This means that there is no more room in the mos_session database table. The fact that the name of the table has 'session' in it implies that a new record is added when a user logs on. Notice the type of values been added : `session_id`,`time`,`guest`. Id of the session being created, time its created and whether the user is a guest or not.
Typically in these sort of applications at some point in time the session should timeout (user logs off or shuts down browser etc) then the session record should be removed from the table. So either there are too many users logged on for the size of table defined or the session cleanup is not working too well. I doubt it has anything to do with the signatures
SilversS2000
Apr 3, 2009 01:27 PM
watchdogd
Oct 27, 2007 10:37 PM
cvc2nr
Aug 6, 2004 03:38 AM
g-s2k
May 17, 2003 02:48 PM
