sql server error
An error occured with the SQL server:
mySQL query error: SELECT p.*,t.*,m.member_id, m.members_display_name, m.members_seo_name,cca.*,ccb.cache_content as cache_content_sig, ccb.cache_updated as cache_updated_sig FROM ibf_posts p LEFT JOIN ibf_topics t ON ( t.tid=p.topic_id )
LEFT JOIN ibf_members m ON ( m.member_id=p.author_id )
LEFT JOIN ibf_content_cache_posts cca ON ( cca.cache_content_id=p.pid )
LEFT JOIN ibf_content_cache_sigs ccb ON ( ccb.cache_content_id=p.author_id ) WHERE p.pid IN( 22706721,22704193,21012251,22692446,22706622,22706 580,22526645,21947989,22141789,22704180,22699422,2 2173713,22665532,22692447,22577163,22676295,226996 77,22071680,22694509,22663510,22702235,22704186,22 704045,22704041,22689794,21945769,22664368,2266156 2,20344397,22344220,21837488,22701272,21817715,218 02197,22694591,22689692,21692040,22694607,22513459 ,22697162,22683928,22677017,21817366,18168241,2213 3476,22687777,22675112,22577627,22689931,21795679)
This is not a problem with IP.Board but rather with your SQL server. Please contact your host and copy the message shown above.
«Return to the index
SQL Error
mySQL query error: INSERT INTO ibf_cache_store (`cs_array`,`cs_key`,`cs_value`,`cs_updated`) VALUES(1,'systemvars','a:5:{s:10:\"mail_queue\";i: 0;s:13:\"task_next_run\";s:10:\"1375773300\";s:15: \"itemMarkerClean\";i:1375773333;s:9:\"loadlimit\" ;s:15:\"0.92-1375749963\";s:14:\"incomingEmails\";b:0;}',137577 3333) ON DUPLICATE KEY UPDATE cs_array=VALUES(cs_array),cs_key=VALUES(cs_key),cs _value=VALUES(cs_value),cs_updated=VALUES(cs_updat ed)
SQL Error
Just happened again at about 11:05 PM CDT. My bf suspects that perhaps some sort of backup is being run (by the ISP?) about this time every night and maybe that's what causes the errors.
I got this one today:
mySQL query error: SELECT cs_value, cs_updated FROM ibf_cache_store WHERE cs_key='mail_processing'
Got two SQL error messages today -- two different machines in two different locations and at different times of day. I don't bother reporting a one-off. When I see it twice in a 24 hour stretch, I figure it's worthy of a report.
The most recent:
10:47pm PT
Trying to load the most recent post in https://www.s2ki.com/s2000/topic/106...#entry22911426
www.s2ki.com Driver Error
There appears to be an error with the database.
The most recent:
10:47pm PT
