This is a soft top, frame, and motor out of a 2005 S2000. Everything is in absolute mint condition except for a small 4.5" tear along the side. There are no wear marks in the usual spots which I've seen occur even on 2004 cars. The car it was removed from had a hard top so the top never saw the sun. It was accidently torn during the removal.
This will be perfect for those that only want the frame to convert to a glass soft top and do not want to retrofit a pre-02 frame. Retrofitting a non-glass window soft top frame to fit a glass window top is a pain and the results are far from perfect. Using a pre-02 frame with a glass window top is merely a retrofit, it is much better and easier to do a full conversion using a glass window frame. I know this because I've done 2 retrofits already and will never do it again. I always recommend getting the entire glass window assembly.
Or if you have some crazy patching skills and want to salvage the top, the rest of the top is in mint condition.
The brand new frame alone without motors retails for $1500 and go for about $1000 at discounted prices. New motors are about $400 more.
PM me with offers
These pictures are of the locations where almost every S2000 soft top shows signs of wear. As you can see, the rest of the top is mint.
