Any REAL GOOD alignment shops?
Hey fellahs.
Just did a set of KSport coils on the Accord.
I need a good alignment shop that can adjust them properly for me and then set the alignment right.
I kinda got the height where I want it, but I need someone that will fine tune and play with the camber settings for me.
If I take it to my normal tire shop and tell them I want it at -2 and its too much and I ask for less I know they'll bitch.
I want a shop that will take the time and set the pre-load/height correctly, and then mess with the camber for me to get the right settings.
Anyone know a place?
Evasive does this kinda stuff.. but alas they're on the other side of the country lol
I am still waiting on my Buddy Clubs to come in for the S2000--- whichever shop does a good job on my Accord, will get my S2000 to do in a week or so as well.
Suggestions please
Suggestions please
Tried a search:
But its cool hopefully problem is fixed by the end of the day and I can find it.
Meanwhile any info u guys have would be really appreciated.
"Search Unavailable
Search is currently offline but we are working to restore it.
Thank You"
Thank You"
I've honestly never heard of a shop adjusting preload and dampening. Coil height and alignment settings are a different story. Just so you know, most shops that adjust coils usually charge 10-15 per corner even of the adjust the coil by 1 turn. You should get the height correct, get a alignment, then mess with the preload and dampening setting to your comfort level.
Fradely Auto
2070 Tigertail Blvd #AA Dania Florida
(954)927-8202
He'll charge you $75 for the alignment, and he does a great job. He used to do a lot of track racing and autocrossing so he knows his stuff and he'll walk you through everything he does... cool guy.
(954)927-8202
The and then raise it just slightly so it doesn't hit...
The problem is the camber is pretty much at 0 right now, so if I go as low as I want, it will rub like crazy.
So I'm thinking I lower it, but raise it just enough to clear it. and then ask them to lower it the extra bit while doing the alignment.
Hope that made sense.
Did a google search to find the info for Fradley... called him up... will be taking the car to him Monday morning.
