brake/clutch fluid
Time to change both my brake and clutch fluids...
What do you guys recommend and/or using yourself? Since I figure my S2000 is my weekend toy, occassionally autox'ed but not tracked, I shouldn't need anything extreme. I'm thinking ATE Super Blue or Motul RBF 600.
Also how many bottles will I need total?
Finally does anyone know where I can pick it up locally?
Thanks.
Thanks.
Clutch fluid is standard brake fluid, nothing special needed there.
For brake fluid, ATE Blue or Gold (color difference is merely for changing fluids, no spec difference) if you push the brakes hard. Otherwise, stock fluid works fine. Speaking of, I need to order me some ATE Gold for a swap...
