Dash question
Ok so lately my lite bulb on my climate control has been acting up and i have spares so i need to change it out. I basically wanna know how to remove the dash cover so i can get to it without damaging anything the rest i am able to do..thanx in advance
remove the 2 screw caps near the cluster, take out the screws, and gently pull the left and right side of the dash bezel and it will come off. the A/C control connects with 1 or 2 screw on the back
good luck
Mitch
good luck
Mitch
good luck
Mitch
good luck
Mitch
Thanx alot Mitch
there are a 4 bolts on the under side of the steering wheel, loosen them up or take tham out and the wheel will drop down lower, then you should be able to work the bezel out around them. I jsut manuvered the plastic, but i wouldn't recomend that it could snap
Mitch
Mitch
