Shops with ITB/cam install experience
Hello to all, I've contacted a few locals regarding a few installations that i'll be needing soon. I would really appreciate if you guys could share you experiences and preferred locations. I'll be needing an ITB install, along with header, cams and a slight tune. The ITB's will come with a startup tune for my AEM but i will obviously need a little more than that. I would much rather have everything installed in Miami but is not a requirement, i could ride the car somewhere for the install if worth it. Thanks
Actually if you could quote me for the install of itbs, cams and header. I'm getting the kit from hitech, the itb kit comes with everything including a startup map for the aem. Comes with the injectors, fuel rail and the to feed the rail and return, according to john from hitech it should be an easy install, unlike most itb setup which need fuel pressure regulator and fuel pressure gauge. Do you guys have a dyno for tuning?
I will have him reply to your message today
