South Florida Owners from South Florida
test pipe
Old Aug 9, 2007 | 11:43 AM
iluvs2ks's Avatar
Default test pipe
ok i got an invidia test pipe and i cant find the defouler for it the 18mm one at pepboys or auto parts are too small( 18mm is the size for the socket to tighten it i assume) caN ANY ONE HELP ME OUT THNKS....
Old Aug 9, 2007 | 11:58 AM
DSMRacer's Avatar
I found mines at Discount Auto, the part# is 42009.
It should look like this.
Old Aug 9, 2007 | 12:22 PM
Alexs '05's Avatar
Yep yep, used the same one. It's a bitch drilling out though, almost burned mine up
Also, be sure you drill it wide enough. The first time, I made it so there wasn't a whole lot of room between the sidewall and sensor, and threw a CEL about 5 miles later.
Drilled it out a little bit more, haven't had a CEL since, and that was about 2k miles ago
Have fun
Old Aug 9, 2007 | 12:30 PM
iluvs2ks's Avatar
thanks guys
Old Aug 9, 2007 | 12:44 PM
crazylarry85's Avatar
Banned
Yo DSM I have a fabricated TP , do you think I can put a Defouler in mine ?
Old Aug 9, 2007 | 12:54 PM
DSMRacer's Avatar
Does your Oxygen Sensor screw in with no problems? If so, then I don't think it should be a problem.
Old Aug 9, 2007 | 01:12 PM
iluvs2ks's Avatar
did you guys use the gaskets from the fouler
Old Aug 9, 2007 | 01:29 PM
Alexs '05's Avatar
I didn't.
Old Aug 9, 2007 | 02:38 PM
iluvs2ks's Avatar
thanks again
Old Aug 10, 2007 | 05:17 AM
DSMRacer's Avatar
The gaskets that it comes with aren't needed.
