Originally Posted by zeroptzero
(Post 24134304)
I'm a white-collar pencil-pushing bloke who knows nothing about electronics, if I can do it , then anyone can do it.
OP you may have to take it to a professional and have it done for you, some Honda dealers will do it, I know my local Honda dealer used to do it for customers. Thanks for all the help. Hopefully I can do it successfully. |
You are not the average bloke Joey. :wine:
White collar and change my timing gears kinda bloke? |
Originally Posted by samson123
(Post 24134309)
There is a DIY out there using a Hamsar relay all done in the engine bay but I didn't like all of the wiring that was needed so I did the mod from the interior cabin. Here's the link https://alavigne.net/Motorsports/Fea...rts/S2000/DRL/ |
(Post 24134312)
The one I used was a Honda part made by Denso, I will see if can track down a part number if you like that could be ordered from Honda.
There is a DIY out there using a Hamsar relay all done in the engine bay but I didn't like all of the wiring that was needed so I did the mod from the interior cabin. Here's the link https://alavigne.net/Motorsports/Fea...rts/S2000/DRL/ it seems really simple now that i saw pictures of it. is there a specific location that my drl module should be located? since the 2006 models already come with them. |
There are no separate DRLs in the 2006 and later cars. The high beams run at reduced voltage all the time. I know they go On when the car is put in gear and stay on as long as the ignition is on. Seems a complex system. Ebay LEDs in the grill simply wired to the ignition seem to be the easiest solution to meet Ontario statutory requirements.
-- Chuck |
(Post 24134304)
Originally Posted by Hfreak
(Post 24134310)
Originally Posted by C63AMG
(Post 24134570)
Knew it! :LOL:
1 Attachment(s)
(Post 24134309)
When I first brought my car here without them I was getting cut off by other drivers, and people were pulling out in front of me dangerously all the time. It's a low sports car and without DRL's people have less chance of noticing you. It was worse on my car because it is silver, a rather dull colour that tends to blend into the background. I found things to be safer once I got DRL's working on my car. A simple LED DRL setup that I run with a dash mounted switch, low draw 20 watt system Attachment 76859 |
