compression test?
Hi guys, i'm about to have a look at a used '00 S2K.
It has been driven by an elderly couple supposedly and has 20,000 kms. Do you think I should get a compression test done?
I don't want to have any problems with this car even though it has the extended warranty.
Any help or input would be greatly appreciated.
TIY
TIY
Certainly, a compression test won't hurt and it will give you a peace of mind. I'm sure you can do it yourself aswell. Just pick up a compression gauge from canadian tire and you're set!
Although with an extended warranty, even if the motor did let go, you would be covered...
I can do the compression test myself, but I am not sure if the seller is willing to let me do it before I purchase the car.
How would one go about it doing this? Also, the car I believe has to be certified before I put the plates on.
Thanks for the responses, please keep them coming
You can get a temporary licence, which i beleive costs 10 bux. This will allow you to get the car certified, emissions tested before you get your own plates...
You can buy the car conditional to a compression test and inspection. I'm sure they won't mind.
BTW, here's modifry's helpful link
<http://www.baustnet.com/honda/misc/compression.htm>
and say one cyl is less, then what ? how do you raise the compression yourself ?
Other than opening up an engine I don't think you can..
I would always do a simple compression test before buying a high strung 4 banger sports car like this one. Odds are the everything is ok but it might save from potential headaches in the future ..
I did compression on my car last year it measured 235 psi across all 4 cylinders.
Just FYI ...Measure at 250rpm at WOT
Nominal 228psi
Minimum is 135psi
Maximum Variation between any two cyls 28psi
Nominal 228psi
Minimum is 135psi
235psi across the board are excellent results. I wonder what they are when the car is new?
I know for a b18c5, the compression can be close to 280psi when new, i guess it should be similar as the compression ratio is close...11 to 1.
