Electronics gurus: need help
Originally Posted by matrix,Mar 15 2005, 04:13 PM
Okay, now tell me exactly how you measured this...where did you put the + and - leads of the voltmeter?
Both were seeing 3.2 volts or so. If I had an adjustable power source, I could vary the voltage across the circuit to see what the correct activation range was, but I don't have anything like that.
Any suggestions?
I'm working on a visio diagram of my circuit.
This is such a simple cct. Just dropping 12VDC down to 3.2VDC so you can use car power rather than a battery.
Try just powering the opener with the 12VDC through the cct and see if the button on the opener works.
You could replace R2 with an pot and that would give you and adjustable output.
If you measured the voltage at the points where it says + - to remote wire and got somewhere around the same voltage as when you have LI battery in, it should work...need a tech day to actually see this.
