help!
See pictures below.
Ok, I will keep the story short, so I don't make you guys read a bunch of irrelevant stuff
Apparently, my S is park under a pine tree and based on the pics, you know what happens on a daily basis or overnight basis.
Yes, those annoying stuff keeps dropping down onto my top, then rolls down to those edges.
My question is, anyone with similar problems or experience? I am not asking how to keep those things away because my only option is not to park near that tree.
Here's what I have tried doing (and some of the ways are not the smartest, lesson learned).
1. Finger-picking those every morning, which doesn't work too well, because my fingers are not skinny. This means I tend to push those things into the gap between the softtop and that black plastic trim (as shown in the pictures), then I cannot get it back out because its stuck inside already.
2. I took my car to the coin wash, then blast the water at it hoping it would blast it off (of course not close up, I don't want the water pressure to chip paint nor kill the top). After that, I inspect, and its all gone, however, I don't see any on the ground as well, so I don't know where did it went.
My questions are:
1. The pines that I have push or went behind that black plastic piece, is there a way I can check if all those pines are trapped behind that black plastic and clean it out?
2. Is the car designed in a way, those pines or any other stuff get flushed out somewhere eventually?
3. If I just open the top with those pines on the edge, will it just run-down somewhere?
Thank you for looking at the pictures and reading my concerns. I really want to keep this car clean. That's why I am concern over such a small thing.
My questions are:
open the roof a couple of inches at a time until the material loosens up at the rear edge then it is easily vacuumed them out. When you just open it a small amount the material bows downward and the pins should all slide down into a fold, so you can easily vacuum them. They won't fall inwards or out of sight, so no worries. Just do a few inches at a time until you get enough room to get at them.
Not sure what you can do for the future with that tree problem other than a car cover , I'd hate for those pine needles to puncture a hole in the top.
I am going to take down that evil tree!!!
Anyone want to vent out any anger on that tree, you're more than welcome to
But thanks to the advice first. I was thinking about doing that JFUSION trick, so I already got a light weight portable vacuum at Wal-Mart, the ones that is good for Auto as well.
However, I am concern on the pine needles that already got stuck behind that black plastic trim, does it get flush out eventually? Or is there a way I can take out that trim or any panels from the trunk to clean it out?
Anyone with a PDF technical manual of our AP1s?
get yourself some 303 protectant and a claybar, if your parked under a sticky tree often. There are 2 drainage holes (probably more), on either side of the soft top assembly when its open near the door jam, makes sure they are not gunked up.
I am too obsessed with my S2K, I start to overthink... I will relax a little bit haha...But I did took down a portion of the pine tree haha...
Thanks Sanjay! haha... I don't think I've seen any blue tops around GTA yet.
So if anyone spot me, wave please, I always wave and greet the S2K I see @ Shell Station on Hwy 7 near times square.
OCMusicJunkie
26
Jul 24, 2006 12:22 AM
at this thread.
