need help - computer wizs needed
JIT Debuggers... anyone know what this is?...
i keep getting this error message when i boot up my laptop...
NotifyAlert.exe - Common Language Runtime Debugging Services
Application has generated an exception that could not be handled.
Process id=0x3e4 (996), Thread id=0x3e0 (992).
Click OK to terminate the application.
Click CANCEL to debug the application.
OK Cancel
then clicking cancel...
NotifyAlert.exe - No debugger found.
Registered JIT debugger is not available. An attempt to launch a JIT
debugger with the following command resulted in an error code of 0x2 (2).
Please check computer settings.
cordbg.exe !a 0x3e4
Click on Retry to have the process wait while attaching a debugger manually.
Click on Cancel to abort the JIT debug request.
Retry Cancel
i have run an updated online scan for viruses and nothing shows up?... did i del a file or something?... more importantly, how the hell do i fix it!...
thanks
ed
OK Cancel
cordbg.exe !a 0x3e4
Retry Cancel
thanks
ed
simon - i tried that... didn't seem to work... none of the error boxes are the same as the one that shows up... i'll try it again...
tri - nothing else is wrong... i can launch all other applications even while the error message box is on the screen...
any suggestions?...
any suggestions?...
Ed, sounds like an application is screwing up.
A few things you can try. Reloading the application or tell it not to load at startup.
Click Start/RUN/type msconfig/click the startup tab/ see if you can find NotifyAlert.exe or cordbg.exe in the startup file list (the file name will be in the command column)
Just uncheck the box to tell it not to run at startup. If that fixes the problem just find out what program usses those exe files and reinstall it.
