Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Noise Diagnostic
Old Oct 13, 2012 | 06:22 AM
CR EH's Avatar
Default Noise Diagnostic
When decreasing speed starting around 60km/h there is a humming sound. It gets louder as the car continues to decrease speed until I stop at which point the noise becomes like a grinding sound.
Letting off on the brakes or applying the brakes has no effect on the sound so I'm quite certain its not brake related. I was thinking wheel bearing but I thought the noise usually gets louder as the speed increases?
Thoughts guys?
-Brad
Old Oct 13, 2012 | 06:44 AM
starchland's Avatar
From the rear? Does using the parking brake change the noise? What about steering does that change the noise?
Old Oct 13, 2012 | 06:57 AM
FluKy15's Avatar
My first thoughts is something to do with the driveline actually. Something like the clutch, slave cylinder, master cylinder, something in that whole assembly anyways. I just say that because it is grinding when stopped, what is still moving when you arent?
Old Oct 13, 2012 | 07:02 AM
starchland's Avatar
Noise stops when car is stopped.check inside pad. Have u had your axle nuts toqd?
Wow mornin mikey up early!
Old Oct 13, 2012 | 07:07 AM
FluKy15's Avatar
Thoughts guys?
-Brad
Yea I just havent gone to sleep yet
Old Oct 13, 2012 | 07:33 AM
starchland's Avatar
Good call red. Hmm clutch feel weird?
Old Oct 13, 2012 | 07:39 AM
CR EH's Avatar
I cant really tell whether its coming from the front or rear when in the car. I didnt try applying the parking brake while driving but I tried braking soft and hard and nothing changed. Steering left or right doesnt seem to effect it either.
Sorry I will clarify what I mean about the grinding. When stopped the noise stops. But when I'm slowing down I would say from 20km/h-0km/h the noise becomes more grinding then humming. Also, the noise is like an off-on-off-on similar to a warped rotor sound.
Clutch feels just fine.
I had intended on torquing the axle nuts over winter...maybe I'm too late I thought I would have more time with only 40,000km on the car.
Note: The noise JUST started this morning, Iv been monitoring my cars sounds lately cuz my exhaust has a bit of a rattle lately since the weather got so cold (I was thinking gasket). Maybe its one of those infamous muffler bearings!!
I realise this is a lot of information but I'm just trying to be as descriptive as possible.
Old Oct 13, 2012 | 07:44 AM
CR EH's Avatar
That is a possibility, the outside surface of all rotors looks fine but I did not check the inside...its tricky with a lowered car lol
Edit: Inside of the front rotor feels fine, but I cant see or touch the rear cuz of the dust shield.
Old Oct 13, 2012 | 08:29 AM
o'malley_808's Avatar
My vote is on the rear diff.
Old Oct 13, 2012 | 08:35 AM
CR EH's Avatar
Why do you guys say dif? I do my dif change every 15,000km and I dont do burnouts lol and I'm N/A!
