ok im jewish and cheap give me a break over here
I originally wanted to get 4 brand new tires most likley the ones that come stock in the 04 s2000
however my budget has limited me :( since my rears are worn to hell and my fronts are still good can i just change rears with new khumo 712's like before and still be safe even tho the front arent as new saftey is important so your opinions would be appreciated.... |
Save up for 4 new tires...
Personally I wouldn't mix the tires (F vs R). |
they are still the same brand.............
just different tread wears, its not like they arent different now...... rears worn to shit and the fronts good... |
I did that before. Unless you autox or do solo events, you won't really notice much of a difference.
You'll be fine as long as you stay with the same brand Darren...
opk khumos again it is :( and by the time these rears go ill be needing new fronts anyways and ill switch then
Sticky S-02s on the front and non-sticky 712s on the rear is in my mind a dangerous combination as it will clearly promote oversteer. I think anyone who has a tendency to drive the car, even just slightly aggressively on the streets would find this set up un-nerving.
no doug, i have khumos on the fronts right now 17's....
He already has 712's on the fronts and rears Doug :stick:
Then what is the issue?
Just run the 712s and save up your money for some RE-50s... I ran 712s on the front and backs as I got them used when I bought the used wheels. |
